HP EliteOne 27" 1000 G2 - Shorted USB - MainBoard DAN11AMB8H0 REV:H
  • modtool
    • Jul 2015
    • 58
    • Italy
    Dear forum members,
    I'm trying to repair this All-in-one machine that had a problem in the usb-c port, maybe the owner connected some shorted device and caused a disaster.
    I found that were shorted :
    Southbridge Intel Q370 SR404 (shorts on main core, 3v rails and data lines on usb ports)
    U89 Intel JHL7340 Thunderbolt controller
    U22 MX25L8006E Thunderbolt controller firmware IC (with a little bump on it)
    When I unsoldered these 3 ICs , the main 3v line has returned to a normal value, around 400mV (measured with red probe on GND and black one on the rail).
    I then soldered a brand new southbridge Q370, cleaned the ME area of the U21 MX25L25635E and, since I don't have available now the usb-c/thunderbolt controller nor its firmware, I gave power to the board by a compatible power supply with a 3 pin plug.
    The board reacts to power, it starts automatically and within 20 seconds it reboots itself, it stays alive but even waiting 20 minutes, it doesn't output any video signal.
    To be more precise, the 24" display lights up at around 18/19 seconds from powerup and displays the message "Display going sleep", then it reboots and you can see the same message again after other 20 seconds, but after then it stay always black.
    Power off doesn't work as it should on an HP machine, i.e. shut it off by just 1 press, you have to keep the power button pressed for more than 4 seconds to shut it down.
    After a forced power down, internal speakers beep (3 long + 4 short) and power light makes some flashes (3 red + 4 white), and basing on the code table seen on the maintenance and service guide dedicated to this machine, it means "The system board displays a power failure (crowbar).*", where the asterisk means "Indicates hardware triggered event; all other events are controlled by the BIOS".
    Original CPU is an i7-8700, I've changed it to an i5-9400 but the behaviour was the same (I'm not completely sure that this board or bios can accept a 9th gen CPU).
    Without CPU, lights and are 3 Red and 5 white, and beeps accordingly (3 long + 5 short)
    Without RAM it gives 3 Red (long beeps) + 2 white (short beeps), accordingly to the service guide.
    Looking from a wide angle, it seems that the system starts its power sequence and reads the BIOS but it can't reach the last step to make the video out, as it lacked something.
    According to you, can it be that the EC is expecting the (missing) usb-c controller to output it pwrdg signal to pullup ALL_SYS_PWRGD?
    Or may it be caused by a not-properly-soldered ball under the PCH?
    Since I have no datasheet nor boardview of this board, I'm trying to go further only by experience, and reading some pcb writings.
    I didn't find any info also on the EC NPCD318HA0DX, even schematics for other boards that use this EC...Do you have any?
    I've taken some measurements on the board, but I can only write them as I found on the board, and I don't know where to measure signals as PLT_RST, ALL_SYS_PWRGD.
    I've found a spot near the cmos battery where you can read some nice signal names, but it's not clear which pad correspond to which signal, anyway here they are:
    JEN1
    1 312 3.24 (connected to 8th pin of U68 EC IC)
    2 777 1.80-1.90
    3 GND 0.00
    4 782 / 1.80-1.90
    5 GND 0.00
    6 784 1.80-1.90
    7 / 0.00-0.25
    8 781 1.80-1.90
    9 GND 0.00
    10 / 0.00-0.25
    11 / 0.00-0.25
    12 / 0.00-0.25
    13 / 0.00-0.25
    14 836 3.24
    15 GND 0.00
    16 / 0.00-0.25
    17 GND 0.00
    18 / 0.00-0.25
    19 GND 0.00
    20 / 0.00-0.25
    CATERR# 0 / 0.00-0.10
    SLP_A# 0 / 0.00-0.10
    CRL 0 / 0.00-0.10
    SLP_S5# 0 / 0.00 0.00-0.10
    SLP_S3# 0 / 0.00 0.00-0.10
    SLP_S4# 0 / 0.00 0.00-0.10
    RSMRST# 444 / / 0.00 3.24
    AUX/CPUPG# 0 / 0.00 0.00-0.10
    PSON# / / 0.00-0.10 0.00-0.10
    PG_170V5 / / 444
    Has anyone a schematic or boardview for this board, or a reference for the EC NPCD318HA0DX from which I could compare signals?
    Please, can anyone suggest something to look for?
  • modtool
    • Jul 2015
    • 58
    • Italy
    Re: HP EliteOne 27" 1000 G2 - Shorted USB - MainBoard DAN11AMB8H0 REV:H
    one week has passed...can anyone give me some advices on this machine?
    Have you seen schematics or boardview somewhere?
    • modtool
      • Jul 2015
      • 58
      • Italy
      no sugestion about anything?
      I know that this machine is not so widespread, but maybe someone can reach some datasheet or boardview?
      Do you know if the absence of the Thunderbolt controller JHL7340 and its firmware chip may block the power sequence?
