iMac M1 24”
    iMac M1 24”
    Hey got a broken screen replacement and I know Apple definitely paired these LCDS to the board. I have the screen removed and it seems very easy to just swap the IC chips on the boards easily. However I don't know what this boards IC chip looks like. I would like to know where the IC chip is that has the true tone information on it. Can you point me to the right area? This also would help repair shops do 24” LCD swaps when they are cracked with known non cracked ones.
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
    Re: iMac M1 24”
    Bump, basically the IC chip is what we are looking for
    sigpic
      Basically bumping this up. I am trying to locate the secondary True Tone chip that belongs to the iMac 24" M1. There are two chips that control that information and help retain the iMacs screen functionality fully. I have attached an MacBook Air 15" M2 as a reference on what chips you need to replace in order to retain True Tone etc. The iMac 24" M1 has one similar chip however, the other chip is nowhere to be found on the iMac 24" M1 board that is similar to 14" 15" and 16" MacBooks with M1, or M2 chips. If you guys can help me locate the second chip, I would like to be able to do a True Tone repair video for this model and future models. Any thoughts on where the second chip is located on the board? If you want me to take a full screen pic please let me know. I have tried to find it but there are no schematics for this board so I am going out of the dark here.
ID:	3556147 Click image for larger version
      sigpic
        mon2 chime in if you have an idea.
        sigpic
          No takers?
          sigpic
            U250 appears to be a flash device - see the nearby SPI test points. If this is a stock flash device, make at least 2 backups with verify before considering to erase and test with experiments.
