USB not working on Asus P4C800-E Deluxe
    Board has no physical damage I can find, except for a plastic corner broken off one Sata connector
    Has been updated to 2nd last BIOS (non-Beta) - I've found last Beta has pickiness problems with certain graphics cards
    Also tried downgrading BIOS
    Fresh install of WinXP shows usual USB stuff in Device Manager
    But testing with USB key lights up the key's LED, and that's it
    Asking WinXP to search for new hardware with the key plugged in, makes no difference
    Fuses near the USB ports show continuity, and I can't see any burnt traces
    Same outcome with a USB bracket plugged into one of the board's headers
    Have replaced all original LTEC 1000uf caps with Sanyo WG
    Various postings on the Net reckon i865 & i875 southbridges are prone to USB going faulty
    Seems to me that USB data lines are kaput - should I give up on it, or try something else ?
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
    Re: USB not working on Asus P4C800-E Deluxe
    I've come across many i865 boards with dead USB ports. Have you tried all of the ports? Usually a few of them are dead, but it's rare that all of them are nonfunctional. I suppose it's possible, though.
      the i855gm in my old laptop blew out all 6 ports (2 on the unit, 4 on the dock). only fix was a new mainboard
      sigpic
      (Insert witty quote here)
        Latest chipset (Intel) drivers package installed? [ 7.2.1.1003 ]
        Overclock?
        Was a 1394 cable/connector ever used on those mobo connectors USB56, USB78?
        Done BIOS reset?
        BIOS default settings from menu?
        Enabled in BIOS? (Advanced header)
        Delete ports from within XP Device Manager, exit and shut down - COLD.
        Unplug mains to PSU and push power button on computer (lights flash, mobo light is extinguished)
        Reconnect power and restart system.
        XP discover ports?
        Does it find USB keyboard or mouse?
        veritas odium parit
          Here is the blurb on that:
          Since mid-2004, the large motherboard manufacturers noticed an increased complaint ratio with motherboards equipped with ICH5. A cause was the insufficient ESD tolerance of certain ICH5 steppings. [In other words the early versions.]
          In particular, when connecting USB devices via front panels, the chips died by discharges of static electricity. Intel reacted to the problem by shipping ICH5 with increased ESD tolerance. Effective ESD preventive measures on USB ports are difficult and costly, since they can impair signal quality of the USB-2.0 high-speed signals. Many motherboard manufacturers had omitted the necessary high-quality safety devices for front panel connectors for cost reasons.
          So to have the problem you need all three....
          1: Early version of southbridge.
          2: Motherboard manufacturer cheaped out on ESD parts. [Thanks Asus!]
          3: User was careless.
          Mann-Made Global Warming.
          - Dr Seuss
            find a USB card, theyre really cheap now a days
              I've tried Intel's 6.3.0.1007 package which I thought was latest for i875
              Not overclocked
              Don't know history of board - anything's possible from the past
              Reset BIOS then load default settings every time I try a different BIOS version
              Is enabled in BIOS (doubt it'd show in Windows, otherwise) - also tried the 4 ports option, instead of 8
              Ports were discovered from a fresh install of XP - haven't tried deleting them, to see if they're re-discovered
              PSU has its own On/Off switch, so definitely mobo light extinguished for various tries
              Haven't tried USB keyboard or mouse - guess I should
                I have tried all four of the board's own ports, plus a bracket connected to at least one of the board's USB headers
                It's a Rev. 2.00, so late model southbridge combined with late model board cost shaving
                I have a NEC chipset USB card, but prefer not use it if I can get onboard ports to work
                  Which revision board is this..?
                  veritas odium parit
                    Rev. 2.00
                    BTW, the Sata connector with broken plastic does detect a disk, so I think unlikely to be the culprit
                      USB keyboard and mouse do not work with it either
                        What resistance datalines have to ground?
                        And once more: very common problem with ICH5, you can't fix that. Thanks god, that mainboard at least starts
                          Have you tried any devices that do not use USB for power?
                          - Dr Seuss
                            That's only if ICH5 is the actual problem.
                            If you just see an ICH5 there and assume that's the problem you may be missing an easy fix.
                            Also as it's know the problem is lack of ESD tolerance for ICH5 you could add ESD filters before you break the southbridge.
                            - Dr Seuss
                              No - I don't have any devices that don't use USB for power
                              Need working USB for USB storage keys, and was hoping for a (possibly) easy fix
                                In that case the problem may be on the power side of the USB.
                                - Dr Seuss
                                  You don't have a Printer, USB - SATA bridge or just active USB hub? Strange
                                  Easy fix is a $10 PCI card.
                                    He did mention that he has a NEC chipset PCI card (for USB). However he would prefer not to use it...and I can relate to this.
                                      Where would I start for diagnosis ? - had a desultory play with DMM testing MOSFETs in the USB area, without identifying anything wrong
                                        See if you have +5v and ground at the ports.
                                        If you don't the device isn't getting power.
                                        What I've done when I wanted front USB and had to use a card is to take a USB cable and clip one end to connect to the front ports then run the other end out the back and plug it into the USB card port.
                                        Mostly did that for old P3 boards to get USB2 out front. [Instead of USB1.]
                                        - Dr Seuss
