Gigabyte GA-G31M-ES2L with BIOS error
  • Chungalin
    • Jul 2014
    • 423
    • Spain
    Not a caps problem, but interesting and freaky repair anyway...
    This MB does POST fine but before booting (or before trying to enter Setup) it shows an error message:
    Warning: MAIN BIOS CHECKSUM ERROR!
    Then it says it'll try to restore Main BIOS from Backup BIOS, but no progress is shown and it stays this way forever.
    This MB is DualBIOS. It has two Flash ICs to store BIOS, Main ("M_BIOS") and Backup ("B_BIOS"), both SST (Silicon Storage Technology) SST25VF040B-80-4I-S2AE, in a SOIC-8-Wide package.
    First I try to ressolder Main IC, to no avail. Then I dessolder Main IC. It still makes POST and show same error message, but when it wants to restore from backup, it just shuts down computer and restarts. Quite normal if it detects something very wrong when trying to write flash IC. Interesting that it doesn't need Main BIOS at all to make POST!!
    Then I pull a SST25LF040A-33-4C-S2AE from scrapped Dell E187242 Connolly, I solder it in place of Main BIOS (no previous erasing, I don't have tools to do this) and let it start... Same POST, same error, BUT now it actually restores Main BIOS from Backup, as it shows a progress dot line. After some seconds it reboots and everything is fine!
    Apparently the main difference between original IC and replacement is max clock frequency, but probably MB accesses it much slower than 80 and 33 MHz. Well, it works, and that's all!
  • q4midz
    • Jun 2014
    • 11
    • indonesia
    Re: Gigabyte GA-G31M-ES2L with BIOS checksum error
    thank you,i replace main bios 25L40 with MX25L80 from samsungtv mainboard and problem solved
    • cekcons
      g1 assassin Rev 1 bios dump - main and backup needed
      by cekcons
      main and backup ic dead so i cant post corrupt bios cause its 01 all over.
      thanks
      01-23-2024, 03:26 AM
    • DeanWy
      WD Sentinel DS5100 (NAS) boot issues
      by DeanWy
      I have a Western Digital Sentinel DS5100 NAS system which has stopped working. It has dual BIOS. I bought the system second hand with an already broken primary BIOS (it rebooted multiple times until second BIOS was used).
      It worked until recently. The system was idle in Windows Server 2012 and a BSOD occurred, I think it was 'critical process died'. Thereafter it didn't boot, it just sat there with no video output and fan speed at 100% (there's a proprietary Windows driver by WD which controls the fan, outside of that it always runs at 100%).
      There...
      07-30-2024, 04:13 AM
    • razenxd
      Gigabyte ga-ax370 gaming 3 backup bios question.
      by razenxd
      Hello.
      A friend of mine gave to me the motherboard of the title.
      He had it in storage for a long time and he couldn't recall what the problem was.
      So I set the motherboard up on my bench and it wouldnt post at all.
      I tried to kick in the backup bios by holding power button and reset button for 10 seconds and then the motherboard booted and I got onto bios.
      Saved exit motherboard booted again.
      Left it overnight at the bench, and today its not booting again.
      Again it booted after I kicked in the backup bios.
      Isn't supposed that when you boot...
      05-30-2023, 04:53 AM
    • DiddiAb
      BIOS Backup / extract 16MB .bin - Lenovo ThinkBook 13s G3 ACN - 20YA0005GE
      by DiddiAb
      Recently I used the official Lenovo bios updater software on my ThinkBook 13s G3 ACN (20YA0005GE). The updating process failed and I got a black screen after powering the device. Of course I did not make an own backup before using the Lenovo bios updater.
      I bought a CH341A programmer and was able to make a connection to the chip while it is still soldered on board. But I did not realise that the chip was a 16MB size and selected the wrong size (8Mbit / 1 MByte) before reading the content of my chip. So the dump I did before erasing the chip is only 1MByte big. I fear that I lost...
      03-11-2023, 03:15 AM
    • nikovmiroslav
      Gigabyte A5 X1 Need Bios
      by nikovmiroslav
      Hi Everyone,I need help with this strange Gigabyte laptop,it turns on with black screen and after 30sec fans on the Max for few seconds and it shuts down,I think the bios is bricked,They say it is Clevo under the hood,there is nowhere on motherboard what is the model which is strange,i will write S/N and P/N from the motherboard,thats only what is writen there and upload old bios,if anyone can help,Thanks!
      Gigabyte A5 X1
      From motherboard:
      S/N: 1TNH55ER1350895
      P/N: 6-77-NH55ERQY-D02-2CGB
      On sticker from the back of the laptop:
      S/N: SN21351J000657...
      08-24-2025, 09:15 AM
