MSI Z170A Gaming Pro Carbon Dented Cap Question
  • Vurhan
    • Jan 2017
    • 6
    • Turkey
    Hello, I just received my new custom pc. I wanted to replace the stock cooler but just realised that one of the capacitors under the cpu cooler (second from the top) has a dent on the top corner.
    My motherboard is z170a msi gaming pro carbon. The dent is either factory defect or happened at the pcshop which buildt my desktop pc.
    Will this kind of dent can effect cpu overclock performance (i7 6700k) or the lifespan of the capacitor?
    How can I understand if the cap is functioning or not? For now computer can operate normally but can things change if i OC? Should I replace the cap and if I should which brand model etc is the compatible replacement?
    There is no hole or anything just a physical dent. The flash makes the dent appear glossy but it is black just like the rest of the cap.
    Thanks a lot!
  • Agent24
    I see dead caps
    • Oct 2007
    • 5069
    • New Zealand
    Re: MSI Z170A Gaming Pro Carbon Dented Cap Question
    It's a pretty small dent and unlikely to do much to the capacitor, but it's still possible the capacitor may have been damaged internally and could fail. If it fails shorted, it may explode.
    If you are worried about it, you should take the PC back to the shop and get them to replace the motherboard.
    -David VanHorn
    • Vurhan
      • Jan 2017
      • 6
      • Turkey
      If the pcshop declines to replace the motherboard, which capacitor should I buy (brand and specifications) to get it replaced by a professional. I am newbie on this topic and highly frustrated by the situation. I cant use my new computer because the dent makes me uneasy. I wont be able to see the cap if i install the cpu cooler and start to use the pc. Any help is highly appreciated and thanks a lot!
      • diif
        • Feb 2014
        • 6978
        • England
        Put the CPU back in or the shield before you bend any pins.
        Stress test the PC, if it falls over complain. If not, don't worry.
        I'm puzzled why you'd get a shop to build a PC then you pull out the CPU to upgrade the cooler. You should have just built it yourself
        • Vurhan
          • Jan 2017
          • 6
          • Turkey
          I know, thats my worst regret... I thought they would do a more prof. cable management than me, I overestimated their professionalism a lot...
          • Vurhan
            • Jan 2017
            • 6
            • Turkey
            What is a reasonable overclock value for i7 6700k to support with good air cooling so that I can understand if my capacitor is working or not?
            • diif
              • Feb 2014
              • 6978
              • England
              My guess is the dropped the cooler on the cap.
              Forget overclocking for now. Just use one of the many programs that will stress the CPU.
              https://www.raymond.cc/blog/test-sys...tem-resources/
              I'd recommend new thermal paste before you do.
              • Drack
                Yup it's me
                • Nov 2016
                • 297
                • Venezuela
                I would tell you if you want to keep this system for a while I wouldn't put more that 1.35v, that Mobo may support more but the cooler may not, and the CPU could shorten its life a bit, air coolers that can do more than that r1 universal or nh-d14/15 or other big cooler but those are not a Good idea because they will bend the CPU PCB, custom water cooling might be the best if money is not a trouble, I don't like the h100i btw
                • Drack
                  Yup it's me
                  • Nov 2016
                  • 297
                  • Venezuela
                  Just make a prime 95 small test, 30 min should be ok
                  • djazeiry
                    MSI Z170A Gaming Pro Carbon MS-7A12 Vers 1.1
                    by djazeiry
                    i got an MSI Z170A Gaming Pro Carbon that have an issue on it , it's the cpu RED LED issue , and i need a dump for it bios if it is possible , or where to check to see if there any fix for it, everything seems to be fine on it, i checked the resistance of the CPU it was 4ohms(i guess it's fine), thank you
                    06-30-2024, 11:09 AM
                  • djazeiry
                    MSI Z170A Gaming PRo carbon Motherboard
                    by djazeiry
                    hello guys ,
                    06-30-2024, 08:02 AM
                    ASUS TUF Gaming FX506HF-HN028-GAMING Notebook F15 Specification for Upgrade or Repair
                    This specification for the ASUS TUF Gaming FX506HF-HN028-GAMING Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX506HF-HN028-GAMING boardview and FX506HF-HN028-GAMING schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                    09-07-2024, 06:38 AM
                    ASUS TUF Gaming FA506IU-HN153T-Gaming Notebook A15 Specification for Upgrade or Repair
                    This specification for the ASUS TUF Gaming FA506IU-HN153T-Gaming Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FA506IU-HN153T-Gaming boardview and FA506IU-HN153T-Gaming schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                    09-06-2024, 11:20 PM
                    ASUS TUF Gaming FX504GD-EN1324-GAMING Notebook Specification for Upgrade or Repair
                    This specification for the ASUS TUF Gaming FX504GD-EN1324-GAMING Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX504GD-EN1324-GAMING boardview and FX504GD-EN1324-GAMING schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                    09-06-2024, 09:01 AM
