3dfx Voodoo5 glitches
  • Justin1091
    • May 2018
    • 50
    • The Netherlands
    Hello all,
    For a few weeks I've been trying to fix a voodoo5 5500 agp video card. The machine locks up when running a 3d application in dual chip mode. I found out that it happens when a driver feature called 'guardband clipping' is enabled. This means that it can run in dual chip mode and that probably the chips are fine. By chips I mean GPU's.
    I've been working with someone over at vogons.org trying to fix the card. Per his recommendation I have replaced all the capacitors on the card. This didn't work. I have another, working voodoo5 which I can use to compare voltages etc.
    Other than asking for tips on what else to try, I have a question. Both cards have a couple of different resistors on them. Why could this be? Images on the internet of the card show the same resistors as on the good card.
    I measured the voltages on the cards and the bad one reads 2.8 to 3.3v (the chips use
    3.3v) and the good cards show 3.0v to 3.3v. That's what the power section reads. It takes 5v and 12v from a molex connector and changes it to 3.3v. 4 ics on the board do this.
    I replaced a suspect resistor on the bad card and the power section now reads 2.6v to 3.3v. After this I have no idea how to proceed.
    So, could the problem be in the different resistors the bad card uses? Or replacing the resistor was something stupid? Any suggestions on how to proceed?
    No idea if this forum is the right one for asking a question like this, who knows
    Thanks in advance!
    Justin
  • Sparkey55
    • Jan 2010
    • 1523
    Re: 3dfx Voodoo5 glitches
    Please attach clear high resolution photos of the bad card both front and back showing all your reworked areas. can you give us some background history of this card? Does it still have the 2 heatsink/fans attached? What exactly are the system specs in hardware in your setup? have you tested the card using official 3DFX drivers? What PSU are you using? Motherboard?
    • Justin1091
      • May 2018
      • 50
      • The Netherlands
      Will post pictures tommorow. As for your questions:
      The card has been in my possession for a couple of years, maybe 8. I got it off eBay and it never worked properly. Back then I used it for some time before getting another card in order to verify if it was indeed not working properly. So, the good card worked fine and I put this one away.
      So now I decided to try fix it. The card has both original heatsinks+fans on them. I have tested the card in a Pentium II 233 machine (some 1998 gigabyte motherboard) and in a Pentium III 800 machine (Asus Cuv4-x) Tested under DOS, Windows 98 and Windows 2000. Used both 3dfx WHQL drivers, beta drivers and 3rd party drivers. Tried 4 different psus.
      Also compared it to the good card. Like this: put in bad card, run game = freeze. Change nothing and put in good card, run game = ok. The one option (that i know off) that makes it freeze is guardband clipping.
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        AFAIK Guardband clipping is just to offload rendering of unseen (not visible) scenery.
        Thus offloading the CPU with resulting higher FPS, don't think that has anything with SLI to do.
        As for the differences in the cards they are probably of different revisions?
        There should be a revision stamped somewhere on the cards.
        Edit: attached pictures shamelessly stolen off ebay showing revision numbers 2100, 2300 & 2500
        • Justin1091
          • May 2018
          • 50
          • The Netherlands
          Ah, I looked at the front of the card and saw REV A. on both boards. Bad card is REV 2300. Good card is REV 2100. I think I should put the old resistor back then (it didn't have a number on it only a blue color). I put a new resistor on it with the value of the good card. Guess you probably can't use other cards with different revisions for parts.
          About guardband clipping you are correct yes, strange that it freezes when it's enabled.
          Edit: guardband clipping does work in single chip mode on the bad card though.
          • Justin1091
            • May 2018
            • 50
            • The Netherlands
            Hmm, 2100, 2300 or 2500 might refer to the week it was produced. E.g. week 25 of 2000. If that's the case the difference in resistors between the boards is still not explained. Could still be revision numbers though.
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              They are revision numbers.
              Nobody would spin a new PCB design each week!
              • brethin
                • Dec 2008
                • 1907
                You need to provide clear high resolution pictures of the card so people can help you.
                • Justin1091
                  • May 2018
                  • 50
                  • The Netherlands
                  Here are some pictures before replacing the caps. https://imgur.com/a/9ovsLMo
                  Notice c90 is wrong, this was a stupid move by me, spotted by someone at vogons.org I have since then replaced it with the correct one.
                  I can post new pictures tomorrow.
                  What I was talking about earlier is R112.
                  In case someone is interested in the vogons topic: https://www.vogons.org/viewtopic.php...a4ac37b0377da0
                  Guy there really helped me, unfortunately he isn't responding for some time.
                  • Sparkey55
                    • Jan 2010
                    • 1523
                    Have you turned off Hidden Surface Removal?
                    • Sparkey55
                      • Jan 2010
                      • 1523
                      I did read one of your posts on another forum that you sprayed an AGP slot with contact cleaner. What exactly was it?
                      • Justin1091
                        • May 2018
                        • 50
                        • The Netherlands
                        I can try turning that off, I'll need to install a beta driver. I'm 99% sure it's disabled in the 3dfx reference drivers.
                        About the contact cleaner no idea, must be a long time ago. Quite useless action as well, and probably unsafe. This is my second attempt at the card. Must have been non lubricating (or however you call it in English - not for switches, pot meters etc.). Has to have been on the current motherboard I use since I never got another one.
                        • Sparkey55
                          • Jan 2010
                          • 1523
                          If the cleaner was anything like WD-40 that is the wrong kind of cleaner and is electrically conductive. Do not use anything containing Silicone.
                          • Justin1091
                            • May 2018
                            • 50
                            • The Netherlands
                            No, it wasn't like WD40. Think it was a spray obtained from an electronics store specifically to be used for cleaning corrosion and dirt. I don't remember the specific can used. Thanks for the tip though! I wouldn't use it again on a PC anyway, well except for switches on the pc case. I'm 100% sure the problem lies with the card, not the motherboard. Anyway, the motherboard's slot is fine and HSR is disabled per default on the old 3dfx reference drivers.
                            According to this webpage, you need to enable it with a registry variable:
                            https://www.anandtech.com/show/683/13
                            I used every driver available to test it, including 1.00.01 (may 2000). That driver doesn't support HSR if I'm correct.
                            Did you see anything worth looking into on the photographs?
                            • Sparkey55
                              • Jan 2010
                              • 1523
                              Have you tried using 1x speed setting on the AGP slot?
                              • Justin1091
                                • May 2018
                                • 50
                                • The Netherlands
                                Yes, including different bios revision for both the card and the motherboard. Card: every single BIOS from 1.06 to 1.18. Tried 3 different motherboards, with different BIOS options (UC vs USWC, shadowing, Aperture Size, AGP speed, etc).
                                The problem can be recreated easily: put bad voodoo5 in: crash. Put good one in: fine. Without changing any option, driver or anything.
                                • Sparkey55
                                  • Jan 2010
                                  • 1523
                                  What is the brand and power rating and +5v and +12V amps on the PSU?
                                  • Justin1091
                                    • May 2018
                                    • 50
                                    • The Netherlands
                                    PSU 1: Aopen FSP350-60PN (350 watt)
                                    +5V 30.0A
                                    +12V 16.0A
                                    I can't remember other PSU's I tried, don't have them anymore. Tried at least three, including higher wattages ones and different brands.
                                    • Sparkey55
                                      • Jan 2010
                                      • 1523
                                      Since both +5v and +12v rails are used for voltage regulation down to a lower voltage set you can try to disconnect either rail one at a time from the card to try to determine if you have a weak or bad regulator section on the card. I have never tried this myself. YMMV.
                                      • Sparkey55
                                        • Jan 2010
                                        • 1523
                                        It is possible that you could have a bad gpu BGA issue. I think the front chip runs all the time and the rear chip only kicks in during 3D detection rendering.
                                        • Christos Tsiligiannis
                                          Marian Trace Alpha sound card repair help
                                          by Christos Tsiligiannis
                                          Hello to the forum.
                                          My name is Christos, I am new to the forum here and i am posting from Greece.
                                          So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                          To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                          So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                          11-18-2024, 05:26 AM
                                        • Kemer
                                          Graphics Card mounting frame
                                          by Kemer
                                          Hello, I removed the graphics card from my laptop and I want to heat it in the oven. What I want to ask is, is it okay to heat the card without removing the metal mounting frame on it?
                                          As you can see in the photo, there is a plastic (black) gasket between the metal frame and the card. It sticks the frame tightly to the card.
                                          I previously removed the metal frame while heating it, but it is quite difficult to separate it from the surface it is attached to. If there is no problem, I do not want to remove it.
                                          What worries me right now is the possibility that...
                                          09-14-2024, 08:57 AM
                                          HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook Specification for Upgrade or Repair
                                          This specification for the HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) boardview and 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon...
                                          09-06-2024, 08:30 AM
                                        • FZG
                                          EVGA Nu Audio Sound Card - Not Working
                                          by FZG
                                          I have an EVGA Nu Audio sound card that is not working properly and I need some help diagnosing the fault (preferably by someone who owns this card and is willing to take some measurements).
                                          The card sort of powers up (LED lights are coming on and the relais is clicking, some voltages are present) but it is not detected in Windows. I tried installing in two different PCs and tried several driver versions but the card was never detected anyway. So I thought this is probably not a driver / software-issue and then disassembled the card to take some measurements.
                                          I found...
                                          03-07-2025, 11:44 AM
                                        • benwaterson
                                          Gigabyte Aorus 1080ti - card not initialising
                                          by benwaterson
                                          Hi there.
                                          Have searched various forums but haven't come across the exact issue I am having.
                                          Bought the 1080ti with a fault (randomly shutting down, black screen , fans full speed etc). Previous owner had replaced thermal pads but many were too thick on inspection.
                                          I tested the card in windows, all loaded up ok. Put some load on the card and it crashed. GPU was reporting 92 degrees C at the time.
                                          Switched the stock cooler out for an AIO water cooler from my 1080 FE, booted the card back up - temps were much better and allowed some load to be applied...
                                          02-05-2022, 11:42 AM
