Got two of these baords yesterday. They have managed to put two Lelon caps on these boards (both bad on both boards) besides high-quality (I guess...) Rubycon YXG-s (who produced the smaller blue 1000 uF caps seen on the third photo?).
Aopen AX37 Pro
the blue caps look like united chemi-con but there is no series TMY found at united chemi-con. an internet search revealed no data on TMY therefore they may be crap and are imitating the look of united chemi-con.
I have seen this on an Albatron PX-865PE board where amongst the 1000uf 6.3 United Chemi-con KZG which are little brown caps, they put also a few EVERCON 1000uf 10V caps which are the same colour and with the same vents as the United Chemi-con caps. Only the writing on the caps is different.
It is curious that the TMY imitate exactly what chemicons look like. perhaps i am wrong?
Rubycon YXG is at the bottom of the series of their caps relevant for motherboard applications, used because they are the cheapest i guess. An OK but not excellent choice for low ESR, the ZL series would be a better choice. At least they will not fail. -
or maybe it is a discontinued product? i am also trying to find the data of (look alike) chemicon LXF, chemicon "sam young" (<- is it really chemicon?), panasonic FJ (<- the top and the bottom seal are exactly like panasonic), and samsung ssl...days are so short when you actually do something..Comment
its amazing how good those company hiding the data sheet of their product... for example, i can't find the datasheet of the good old HFQ panasonic anywhere, even on their website... but finally found some link on a europe site about the comparison of FC and HFQ. maybe panasonic already kill the link for HFQ or other discontinued product.days are so short when you actually do something..Comment
chemi-con discontinued series
http://www.chemi-con.co.jp/english/c.../daigae_e.html
they should just point to google instead of having an index.htm in their site. so much hidden information.
LXF replaced by LXY
Samyoung Electronics http://www.samyoung.co.kr/
Since May 03, Samsung no longer make electrolytic capacitors. Their division taken over by Samwha Electric http://www.samwha.com
no need to worry too much about HFQ for our applications, it is probably quite similar to FC.Last edited by willawake; 05-18-2005, 07:55 AM.Comment
Re: Aopen AX37 Pro
good work Sulbert. this weekend we are having many happy stories.Comment
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by RUllER
This is not a fake Chemicon, it is genuine
Many companies are outsourcing to Chinese factories....-
Channel: General Capacitor Questions & Issues
by flibidyI have here a Magnum IA.100 which belongs to my parents.
The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
What Ive done........8 Photos-
01-01-2025, 01:26 PM -
by sushy74Good evening, I have a problem with this lcd tv (UNITED branded with BEKO electronics), I would need to fix it to try some old video game consoles as it has digital / analog tuner.
I found it after years and once I turned it on I realized that it took a while to go from standby to operational, but above all I notice that it is blocked in some way, let me explain ... no physical button on the TV works, using the remote control (which is a compatible one) only some keys work, such as the one for power, volume, numbers and little else, I cannot change source and above all it does not access... -
by momakaAaaaand… we have more retro-PC nostalgia repairs again.
This time it's with a XFX GeForce 6800 XT AGP video card. The XFX model number is PV-T42K-UDE3.
As with many early XFX cards, crap caps are the main issue here. The first one I bought and recapped was back in 2017. I've been meaning to post about it for a long time, but never got around to it due to the card needing a better heatsink/cooler to test it fully with the recap (more on that later on.) In the meantime, I acquired a 2nd one of these cards not too long ago (February.) Not like this makes any difference. Both... - Loading...
