need help to recover fine usb on asus m4a785dm pro mb
    got an m4a785dm pro
    got the boardview
    pb is:
    usb sometimes works sometimes not
    specially on usb wifi stick
    works fine and stops....
    its arrived after a short circuit on usb external drive
    pse help got not idea to begin with
    ty
    Re: need help to recover fine usb on asus mb
    none to help me with .?
      Re: need help to recover fine usb on asus m4a785dm pro mb
      Heloo,
      Put an Internal USB Port Cards,Pci or PCI-Express.
        Originally posted by Aliencomputres View Post
        Heloo,
        ty
        but its not that i want...
        i d like to repair and solve the problem
          Have you checked for bad solder joints on ports, bad caps?
          use a usb power meter and see what voltage its putting out on the power lines.
          check for broken lines to the usb port and inspect the port see if any fingers are loose / broken.
          give it a hard look and check for anything that looks strange on the board
          it could be shorting out intermittently if the whole bus drops for all ports.
          "edit" when the ports drop do you see a device in device manager drop/go error?
            If exist check 0 ohm resistors and/or recoverable fuses in series in the 5V power line going to the USB socket. The short may have decalibrated the resistor/fuse so you may have an unintended voltage drop on these parts. As next I'd check the power regulator generating the USB 5V from 12V ATX power (probably UPU2, or UPU1, don't know which USB port you mean).
              ty both for replies
              well the pb is on all usb... begin to work fine and never at same timer begin to work uncorectly... i suspected 1st the brackets but its same with direct port on the mb
                hi
                there are some 0 ohm resistors there....
                will be simple with a termal stuff
                  You can measure them incircuit.
                    hi
                    will see tomorrow
                      hi did not check yet but i try to follow the diagram
                      so...
                      most coponents are passive except UPU1 connected to UPU2
                      goes to UD1 and UD2
                      manage also the usb/sata and usb/lan block
                      as i said the pb began with a short by a deffective usb external disk
                      and is on all usb connector
                      i suspect this one UPU1 what is a usb multiplexer
                      what u think ? and how may i control it ?
                        ps ive no ud1 ud2 ud3 on that card
                          same pb on all usb...
                          btw ive checked all 0 ohms... theyre right
                            ok finished... the card is 15 years old and some tracks are dead...
                            mark as resolved card is dead
