[Request] Asus A320M-k updated BIOS Dump
  • abel2b
    replied
    Re: [Request] Asus A320M-k updated BIOS Dump
    ??? nothing
  • abel2b
    replied
  • abel2b
    replied
    Originally posted by SMDFlea View Post
    Take the CMOS battery out before programming ,and use the clear cmos jumper afterwards. (LENGTH 800)
    Well I reflashed everything as instructed and no luck!
    No video, post, beeep nothing just amber LED and CPU come on...
  • abel2b
    replied
    There is a difference between the 6402 i extracted and your file, theres a serial number in yours,i don`t know why,but it should be ok,take the cmos battery out and flash it .
    OOH yeah the 6402 *.bin file, well I added DMI data from backup with FD44Editor_0.9.2 that is why serial number, UUID is there
    I´ll try in just a minute
    replied
    Originally posted by abel2b View Post
    Not Quite sure what you mean by (LENGTH 800) but I believe so....
    Just in case I will attach Asus website latest CAP file and extracted Bin by Uefitool please verify ... THX
  • abel2b
    replied
    Take the CMOS battery out before programming ,and use the clear cmos jumper afterwards. UEFITool has removed the CAP header ok 0 - 7FF (LENGTH 800)
    replied
  • abel2b
    replied
    According to Asus CPU support for this board, a Ryzen 5 4600G is supported or validated since BIOS Ver. 5862 so I downloaded latest version 6402…
    I connected my CH341A (Green) programmer with 1.8V adapter to the board.
    I identified pins as follows…
    Then I fired up NeoProgrammer V2.2.0.10, identified chip as Gigadevice GD25LQ128C [1.8V] and read data successfully and saved backup…
    OK so then I opened the updated BIOS CAP with UEFITool NE Alpha 59 , then - right-click onto the listed “AMI Aptio capsule”, choose the option “Extract body…” and save it as *.ROM file. (File size 16,384 KB)
    I then erased and verified blank chip with NeoProgrammer successfuly, then opened new *.ROM file and flashed, Successfully… I removed programmer cables, installed CPU and powered up… :frowning_face:
    It didn´t POST, boot or display anything (Fans running)
    I also have tried with no luck, manually editing *.CAP file with HxD and removing first 2048 bytes and saving as *.ROM, I also tried Asus CAP to Bin Tool to create *.ROM file, I tried flashing with CH341 programmer original soft, with AsProgrammer I even flashed with Flashrom for windows, in all cases no errors where displayed… yet Mother Board refuses to POST…
    SOOO! What am I doing wrong!
    what is the proper way to do it…
    Any help would be greatly appreciated…
    P.S please excuse my English, it is not my native tongue…
  • abel2b
    replied
    Originally posted by hoaca388 View Post
    post your original corrupt bios here.
  • hoaca388
    replied
    Post your original corrupt bios here.
  • abel2b
    started a topic [Request] Asus A320M-k updated BIOS Dump
    Hello, anyone have BIOS Dump (ROM/BIN) for Asus A320M-K, dump has to be version 5862 or higher, so I can use with Ryzen 5 4600G CPU.
    I do not have a spare older generation compatible CPU to boot and update via Bios EZFlash Utiliy...
    Also I will be flashing via CH341A programmer with either (AsProgrammer, NeoProgrammer, Flashrom)
    I´ve tried the usual extraction of file with UEFITool --->
    Open the *.CAP file, do a right-click onto the listed "AMI Aptio capsule", choose the option "Extract body..." and save it as *.ROM file. from latest BIOS *.CAP file and later flashed with no luck... board will not POST anything
