Managed to fix it myself using an hex editor, writing FF from 0x00037000 to 0x00037700. Address range found for G6 searching this forum. PC works fine now!
HP EliteDesk 805 G6 Mini PC
Great forum - stumbled upon this trying to remove BIOS password from a few EliteDesk 805 G6's I've got. Was able to get a dump of the bios, I THINK. Chip says - MX25L3255E. asprogrammer / neoprogrammer doesn't have that one listed. Was able to pull presumably the BIOS using MX25L3275E - the hex shows a fair bit of non-gibberish strings so I think its good. However the RCUnlocker shows Missing Unlockable content when I drop the BIN in. Any help appreciated!
HP EliteDesk 805 G6 SN: MXL1143X8F MB: DA0F92MB6F0 Rev FAttached Files
Well per this link: https://smh-tech.com/macronix-mx25l3255e/ I wonder if im not grabbing the BIOS, since its only a 4MB chip. The other chips on the board don't seem to be marked that they are bios chips though. Could someone let me know where the BIOS (and I guess the PRVROM) are located on the mobo? It seems I need both...
Originally posted by ctvedt View PostHi, would really appreciate help removing BIOS password on my 805 G6 mini pc. Unable to use tools like RCUnlocker as this does not support this 32MB chip. HPUnlocker does not list EliteDesk or G6 as supported models, so I'm reluctant to use this tool.
I have attached verified reads from both chips (marked BIOS and PRVROM)
Model: HP EliteDesk 805 G6 Desktop Mini PC
Serial No: 8CC1281J87
Product No: 2Q296AV
Chip: MX25L25673G
Well, after I found the right BIOS & PVROM chip - hint, its not the SOP8, its the 2 WSON8 chips under the HDD sled / next to the PCI wifi slot - I was able to desolder, dump, and fix! My first time using a heat gun, and on as small of a chip to boot.
Originally posted by ctvedt View PostManaged to fix it myself using an hex editor, writing FF from 0x00037000 to 0x00037700. Address range found for G6 searching this forum. PC works fine now!
I did *JUST* the PVROM chip - NOT the BIOS chip, as a few others have mentioned.
Hi i have similiar problem , i have hp dm 805 g6 mini but my chips are different , both of chips are gigadevice 25b256dyig 32MB and dumped it with gd25LQ256C_1.8v with ASProgrammer and ch341a programmer, can someone check if this is ok to play with removing bios password ?
Serial No: 8CC2383930
Product No: 2Q294AV
Chip: GD25B256DYIGAttached Files
Originally posted by Michael.87 View PostHi i have similiar problem , i have hp dm 805 g6 mini but my chips are different , both of chips are gigadevice 25b256dyig 32MB and dumped it with gd25LQ256C_1.8v with ASProgrammer and ch341a programmer, can someone check if this is ok to play with removing bios password ?
Product No: 2Q294AV
Chip: GD25B256DYIG
Serial_8CC2383930
BuildId_20WWQ7FT601#SABH#DABH
Feature byte_3E476J6S6b7B7H7M7Q7T7W7maBapaqaubhcAdpdqfPhKhZjhk8mEnWpq.DG
Product_2Q294AVAttached Files
Become a Badcaps supporter
Thanks to all supporters.
