Reading Serial Midi data with an oscilloscope
  • zombie.guitarist
    • Jun 2023
    • 28
    Hey all, I have one last thing I'm looking to fix with my Synthaxe. This time, the schematics I have are actually the same as the PCBs I have.
    The Synthaxe, works as its a guitar midi controller hooked up to a floor pedal. Thats the most basic way of using it, and it has a midi output. You also can connect a console to it, that stores your tunings and other things. The console has 8 midi outs, as well as a midi in and midi thru.
    When I first got the unit, I thought I was using it wrong, but it turns out its just broken. The 8 midi ports on the console don't output any data, but the midi port on the footpedal DOES. The console also works fully as Ive tested everything on it. If I remember correctly, when I tested the broken ports to
    a real keyboard, I could remotely change patch banks on the keyboard from the console, but it wouldn't produce any midi data.
    So here are the schematics, one is for the console, the other is for the floor unit, but you can see where the working midi output is located. Ive also connected the continuity to everything as well as the resistance.
    I believe the fault is between IC12 (63B50) and the midi outputs. I believe IC14 (74HC574) only turns what output you want on (you can sent the console to have any combination of outputs on). IC12 also has all the data coming into it properly and most of the connections are bussed to IC10 and 11, which work. I replaced IC8 because it looked like the UARTC line wasn't working, but that didn't fix the issue.
    My problem is, I'm not sure how to test if the Tx line of IC12 (Pin 6) is outputting data? Because if it is, the issue could be IC32/IC28 or maybe IC13. To a smaller degree, MAYBE IC27/IC15 but it would be very suspicious if they both were bad.
    Again, midi DOES work, as it can output to the footswitch, it just doesn't output from the 8 ports.
    Thanks again for all the help!
    • 31131
    Re: Reading Serial Midi data with an oscilloscope
    ic14 selects which ports will be driven,
    data comes from ic12, goes through a switch (ic32) and is then buffered by ic28.
    the switch is controlled by ic13 and appears to be to create a loopback between ic12 and ic10 - maybe for a diagnostic check.
    what test gear do you have?
    • zombie.guitarist
      • Jun 2023
      • 28
      Just an simple oscilloscope and a DMM. I tried looking for videos about reading midi data online, but the only thing I could find was someone using a working DIN Midi cable, into an Arduino. Im unsure how to read that kind of serial data directly from the Tx line itself.
        • 31131
        scope pin6 of ic12 - 1v per division.
        • zombie.guitarist
          • Jun 2023
          • 28
          Ill try that again. I tried scoping the working midi port as a reference to see what a working signal would look like and wasn't getting anything. I think i was at 2V. I tried all the different time divisions as well and couldn't see any data, even trying to trigger it. But more importantly, what you're saying is you don't really need any other equipment since I'm not trying to decode it?
            • 31131
            your just trying to see a squarewave from the chip - it's 5v so 1v per division is good.
            if your probe is x10 make sure the scope knows that or set the input to 100mv per division if it's ancient.
            test the scope settings by looking at pin11 - that should have a signal or your cpu is dead!
            • zombie.guitarist
              • Jun 2023
              • 28
              Ok I can do that. I can't remember if I tested pin 11, as its bussed to IC 10 and IC 11 as well and figured if those 2 work, it should be an issue with IC 12.
              FWIW, I tried testing the output on the midi port that worked on the footswitch. I put the scope inside the MIDI Din, and was able to read 5V on the one pin, but nothing on the other, but I knew that worked and was output MIDI data from the controller. So I thought perhaps I just couldn't read the data with what I have.
              First, I might re-trace what that working midi port is connected to, and see if I can scope that directly to make sure I'm making a strong connection, and if I actually am seeing data. I went in thinking that same thing, its just gonna peak 5V up and down, that SHOULD be readable, unless its so fast my scope cant see it. The baud rate for Midi is 31,250.
              • zombie.guitarist
                • Jun 2023
                • 28
                I wanted to chime in with this. To double check, I traced on the footcontroller, the signal path for the working midi, so I could probe it easier and test what correct data would look like on the scope. I didn't get anything. 5V was tied to the correct pin, but when I tried the Tx data pin for the midi, I didn't get anything. Tried multiple voltages and even the fastest/slowest second readings I could and didn't see anything. Again, I KNOW that midi port works. So, there must be something that reads that kind of midi serial data properly. It could be that the data moves so fast the scope can't read it.
                  • 31131
                  what scope is it?
                  you cant just look at the connectors, MIDI is using a 5v line for common and the signal just goes to ground.
                  you have to look at the inputs to the buffer chips - or add a 10k resistor between the midi signal pin and midi common to create an alternating signal
                  • zombie.guitarist
                    • Jun 2023
                    • 28
                    what scope is it?
                    Ah ok, did not know that. I have one of those handheld scopes, the FNIRSI-1C15. Last night when I was probing, I can't remember exactly what I was probing, but it was either Pin 11/13 on the 74C906, or Pin 4 of the 220 Resistor array. Ill take another look.
                    • zombie.guitarist
                      • Jun 2023
                      • 28
                      Success! You were right about not only probing the input of the buffers, but also using the 10x. I tested the working MIDI, and got Midi data from pin 10 and 12 of the 74C906.
                      Now, moving on to the actual problem, the console. IC 12, 63B50.
                      The results are, I got signals from everything (well except the RxD pin cuz nothing was connected to it). But I got working signals for the TCK/RCK/E/RW/CS (when midi data was present)/IRQ (also when midi data was present) and all the data lines. The ONLY pin, I could not get data from, was the Tx line Pin 6. Now knowing how to read the serial data properly, and all the other inputs/outputs working, I'm supposing this chip is bad and should be replaced?
                        • 31131
                        i would lift pin6 and check it again, or swap it with ic11 and then check pin6 on both.
                        reason: it could be the input pin on ic32 shorted to 5v or ground.
                        inputs are protected from static internally with diodes, if one fails the input gets shorted to a power rail.
                        • zombie.guitarist
                          • Jun 2023
                          • 28
                          Thanks. Will check that at some point. One quick question though. Would it be a little easier or less destructive to just replace the IC32 4016 first?
                            • 31131
                            you could just desolder ic32 and then re-check pin6 of ic12
                            i presume from your words you dont have professional desoldering gear.
                            i can pull a 40 pin chip in about a minute and leave it and the board clean
                            • zombie.guitarist
                              • Jun 2023
                              • 28
                              I used to have a good desoldering gun when I was making NES games, and desoldering chips was a breeze! For some reason, with this PCB, it seems much more fragile. I already had lifted a trace even though I was STUPIDLY careful on IC 14, but it was an easy fix because of that Data bus, so I just jumped it to another pin. I ended up getting another desoldering gun/pump that seems to work pretty well. I'm just trying to be as careful as I can. I did just buy another console and step pedal as a backup, but I don't know if those are broken too.
                              • zombie.guitarist
                                • Jun 2023
                                • 28
                                Update. Removed the 4016 (IC32), and still no data from IC12 pin 6.
                                I actually took the chip out easily and lifted a part of the trace, but I put in a socket, and checked it for continuity and it was still connected. Its like these pcb traces are more fragile than the NES PCBs.
                                  • 31131
                                  i have seen people desolder the pins and then use hot air from the top before pulling the chip - never tried it myself
                                  • zombie.guitarist
                                    • Jun 2023
                                    • 28
                                    Doesn't sound like a bad idea if you have a hot air gun. Anyway, I'm gonna order a 63B50P from China since no one else has em. Hope that does the trick.
                                    • zombie.guitarist
                                      • Jun 2023
                                      • 28
                                      After a couple of weeks, I finally got a 63B50P chip. Put it in and still nothing haha. So it isn't the chip, but to be fair, I just tested output. I didn't read the Tx pin with the scope, but none of the other ports worked so I don't think it could be anything else after that. So it may be something feeding into
                                      the IC12, I just can't think what else.
                                        • 31131
                                        or the new chip is bad.
                                        • gabri2211
                                          Xbox Series X Console Won't Turn On - Broken Nexus Connector on Mainboard
                                          by gabri2211
                                          Inside the console there is a small circuit board (see photo) that contains the main power switch, the one on the front.
                                          This circuit board connects to a 10-pin flat cable called NEXUS that terminates on the motherboard.
                                          This NEXUS connector broke.
                                          Can anyone tell me, while waiting for a replacement, if it's possible to turn on the Xbox by disconnecting this circuit board and making some modifications (like adding a small power button) on the motherboard?
                                          The Xbox has a power supply that provides 12 volts on all outputs, so the power...
                                          07-28-2025, 07:13 PM
                                        • Tarot Superstars
                                          How not to Damage an Oscilloscope
                                          by Tarot Superstars
                                          Hello.
                                          I have jut got my first analogue oscilloscope. An Isotech 620 20MHz.
                                          I want to learn how not to damage it, and I found instructions on the internet obscure.
                                          They talk about ground, earth, floating ground, this, that....
                                          But they don't actually say anything anything useful so far.
                                          I want to know:
                                          Don't connect exactly this to exactly there or it blows up.
                                          For example, I am tracing a signal from a function generator in an audio amp, or testing for voltages in different parts of a circuit.
                                          I want to know what not to connect...
                                          08-29-2023, 02:27 PM
                                        • SuperAman
                                          PS5 HDMI port diode reading?
                                          by SuperAman
                                          I did an hdmi port repair for a PS5 and I lost the small diode z71 SOD923 on the back of the port. I did a trace repair for pin 19 of the port as well. Without the diode I get no display at all. I tried replacing the diode twice but after I get flux on it the marking comes off so I can't tell if I have it on the right orientation. When I measure I get a reading of 1(open) and 923 in diode mode. Is 923 a normal reading for these and also which side should the reading be with regards to the arrow on the board?...
                                          02-03-2024, 10:16 PM
                                        • edugimeno
                                          Diagnose real-vintage Strong-Hammer arcade machine
                                          by edugimeno
                                          Hi there!
                                          My friend wants me to help him repair his old-real-vintage strong-hammer machine. Well it's only 90% real as the force applied doesn't lift the weight itself but it is measured and it moves a motor that lifts the weight
                                          I am attaching several pictures of the machine.
                                          It basically has 2 sides, left side has
                                          • 2 x 220->12+24v transformers
                                          • 2 relays (1 moves motor UP, other moves motor DOWN)
                                          • IGF and breakers for safety
                                          Right side is shown on pictures. It has 3 boards ( top-down)
                                          • Logic board. Receives 24AC and recitifies it into DC. Contains a uC (M80C85)
                                          02-29-2024, 11:05 AM
                                        • grimacelord
                                          PS5 | CFI-1215A | EDM-030 | Stuck In Safe Mode 99% Processing
                                          by grimacelord
                                          I have a CFI-1215A PS5 (EDM-030 board) here that won't boot normally. It currently will immediately boot into Safe Mode upon power button press with a screen that says "Processing" and then a progress bar that usually begins around 75-84% and slowly climbs up to 99% where it will hang forever. The console will not ever escape past the 99% mark.
                                          Things I have tried:
                                          1. Tried force booting into Safe Mode by pressing and holding power button for 2 beeps so I could use a reinstallation USB, but the console still boots into Safe Mode with the...
                                          03-27-2025, 12:09 PM
