QNAP TS-469L NAS shutting down randomly
    I bought this NAS as "turns on then straight back off again". When I received it it had no trouble staying on, just the RAM stick was in the wrong slot so it wouldn't POST. I was hoping that was all that was wrong with it, but it's now started randomly shutting off once a week. When I find it off it will fire straight back up again if I hit power, no need to power cycle. Nothing ever in the logs aside from "the last shutdown was unsafe".
    It's got an internal PSU, an FSP250-50LC (which is wildly overkill for the hardware really). The electrolytic caps in the PSU all look OK visually but given its age (about 10y I think) I am wondering if a recap would be a good place to start? No electrolytics on the MB if memory serves. It has an Atom D2700 so not affected by the LPC clock issue.
    I've got it on a TP-Link KP105 with a small Python script to reboot it whenever it drops off the network so it's limping along for now, just hoping it doesn't get worse!
    Cheers
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
    try a different psu, and scan the harddrive for smart errors
      New PSU is on the way, HDDs are definitely OK.
      I saw it actually fail today, it was unreachable on LAN for about a minute but LEDs still suggested normal operation, then everything shut off. I am starting to wonder if RAM might be faulty.
        Update, it got worse to the point it was shutting down every few hours. I've since replaced the PSU with one from a TS-453 and it seems to have fixed the problem, over a week now without a shutdown.
          You need to take a close look at this power supply for what is going on with it
          9 PC LCD Monitor
          6 LCD Flat Screen TV
          30 Desk Top Switching Power Supply
          10 Battery Charger Switching Power Supply for Power Tool
          6 18v Lithium Battery Power Boards for Tool Battery Packs
          1 XBox 360 Switching Power Supply and M Board
          25 Servo Drives 220/460 3 Phase
          6 De-soldering Station Switching Power Supply 1 Power Supply
          1 Dell Mother Board
          15 Computer Power Supply
          1 HP Printer Supply & Control Board * lighting finished it *
          These two repairs where found with a ESR meter...> Temp at 50*F then at 90*F the ESR reading more than 10%
          1 Over Head Crane Current Sensing Board ( VFD Failure Five Years Later )
          2 Hem Saw Computer Stack Board
          All of these had CAPs POOF
          All of the mosfet that are taken out by bad caps
            I think I am just going to throw it in the bin, lol. New used one was £25, I imagine it would be a hiding to nothing trying to fix the old one when there's nothing visually wrong with it.
            Two weeks now with no shutdowns despite heavy loads so seems to be fixed.
