No Power - Only Beeps - Missing 5V Rail Near F7502
  • grimacelord
    • Jan 2017
    • 363
    Working on a PS5 that came to me for no power. Console would not beep or power on when pressing the power button initially. Board model is EDM-010.
    I began by taking the console apart and performing a visual inspection on the board. Everything looked fine. I then tested the various fuses across both sides of the board and found that F7001 and F003 were both blown. I then looked closer at F7001 and found that the right side of the fuse read short on my multi-meter, so I injected 1V and found that a capacitor near the F7502 was getting hot, so I removed it and the short cleared.
    I then replaced the two blown fuses and partially reassembled to test and still no power on however the eject button now makes a beep sound when pressing it and the power button will make a beep sound only after pressing the eject button first but won't beep if you didn't press eject first.
    I then disassembled again and checked the fuses again and they are all ok, so they didn't blow again. I then checked for shorts and found none so I then started probing for voltages and found that a pad that is supposed to have 5VSTBY present in standby mode is missing. It's supposed to have 5V but it's reading 300mV. That pad also happens to be next to where the shorted capacitor is.
    I made a graphic showing what I am looking at here and was hoping someone could take a look and hopefully help me out with this one because I am not sure what to check from here.
    Thank you!
  • ADRdaniel
    Open sauce 2025
    • Nov 2023
    • 7
    Check the two TI 3219A 5v Synchronous Buck Controllers by f5071 and by the red caps
    • grimacelord
      • Jan 2017
      • 363
      Thank you for the reply. Just for clarification, "...and by the red caps", do you mean the component in my picture I posted in the original post?
      • Nagy Daniel
        Lowest possible resistance on laptop motherboard rail - Guide Table request
        by Nagy Daniel
        Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
        I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
        I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
        So, I generated a table with AI so I can...
        03-04-2025, 08:24 AM
      • BC_TechForum_drb
        Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
        by BC_TechForum_drb
        Sub: Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
        Ref: 1/ MacPro6,1 Late 2013/A1481 MD878LL/A (3.5 GHz 6 Core Xeon E5-1650v2)
        Gfx-B: APN: 661-7548 PPN: 820-3533-A AMD FirePro D500-B 3GB Vmem
        2/ Figure 1 Gfx-D500-B Front Facing
        3/ Figure 2 +5v supply (zoom-in)
        Intro:
        While troubleshooting a Mac Pro(6,1) referenced above I discovered the +5v secondary supply did not stand up on the D500-B graphics card as a result of a missing enable signal. The +3.3v secondary rail was the only rail that did standup. I tried to perform...
        12-07-2023, 09:55 PM
      • theflyingsquirrel
        Samsung Chromebook Pro missing 1.2V power rail and no boot
        by theflyingsquirrel
        I am trying to repair my Samsung Chromebook Pro. There is no boot. Upon turning on, the screen is blank and there is no backlight. Power LED is blue. I tried refresh with power and esc refresh with power with no avail.
        When I measure the 1.2V rail, it is pulsing. It will jump from 0 to 1.2V then 0 again. I replaced the 2 MOSFET and even power management IC and it is the same. Resistance from midpoint between mosfet to ground is 0.5 kOhm but it will show 250 Ohm first before jumping to 0.5 kOhm. So it feels like it was charging up some capacitor. Since MOSFET and IC was replaced, I...
        06-11-2025, 08:11 AM
      • Grucha98
        Zotac gtx 1060 3gb missing one rail
        by Grucha98
        Hello everyone, i have zotac gtx 1060 3gb, and it has missing one rail. I think its 1v but I'm not sure. This rail has 34 Ohms, but after test on on my testbench, it drops to 2ohm, after some time it back to 34 Ohms. Next to this coil is up1727q. And there are 3,3 on vin pin and 5v on vdd pin. I changed this chip with another one but it didnt help. When i tried Short circuit test, core didnt heat up so maybe its still alive. I dont have thermal camera :/. I dont have boardview and schemstic for this GPU too. What should i check next? Or maybe its just dead core?
        04-11-2024, 08:09 AM
      • noflux
        Surface pro 5 (Model 1726) missing 3.3V power rail
        by noflux
        Hello All
        Have a Surface pro 5. Main board model; M1007506-015. Main 15v power rail is present.
        1st image;
        Missing 8v rail at inductor (circled in blue). Suspect main cause is power is being drawn at dead short on C4517.
        2nd image;
        3.3v rail was measured at 0.17v (at top most capacitor with red cross in 1st image).
        Capactors crossed out in red are shorted.
        Are the 5v and 3.3V rails tied in somehow e.g. generated at a single IC?
        2nd and 3rd image;
        C4517 circled in red is shorted at pin...
        06-18-2023, 03:45 PM
