Ps5 edm-40 blod
  • Puuhis79
    • Nov 2020
    • 27
    • Finland
    Ps5 edm-40 blod
    Ps5 came with only beeps nothing else, i hook up uart -> ram bank4 error (hynix chip) ordered same type, replaced chip with bga station, now gives fan spin and blod 1s
    and uart gives 80801F12 code… tried to look up the code but no succes. Atleast message for ram bank4 is gone
  • Puuhis79
    • Nov 2020
    • 27
    • Finland
    Update, I replace RAMs 2, 5 but same code still, next plan is starting to replace rest RAMs one-by-one to see if code changes...
    • Puuhis79
      • Nov 2020
      • 27
      • Finland
      Update:
      RAM´s 2 and 5 are changed, still same code... So 2,4,5 are changed...should I continue changing the rest or something else?
      • notedop
        • Nov 2023
        • Netherlands
        Have you been ever able to fix this 80801F12 error code? I've got one with the same error. Also EDM-040. Originally completely dead because it missing the NOR chip. I flashed one from another EDM-040 donor board and then it came to live. The original error codes where pointing to the SSD controller, SSD PMIC. After clearing the codes I now only get the 80801F12.
        First thing I'm thinking is that I didn't update the serial and board ID in the NOR to match the actual. If that doesn't work I'm thinking it might be the SSD controller. Interesting enough the previous owner had also worked on the RAM IC's. Not sure if they got replaced or just reflowed.
        • Puuhis79
          • Nov 2020
          • 27
          • Finland
          No I´m still working with this, code is still same 80801F12... plan is to replace all Hynix chips, but lets see... One thing crossed my mind, is bios checking memory chips etc...if NOR chip needs to be modified or update after RAM chip replace...
          • jkyoho
            • Oct 2020
            • 17
            any updates on your EDM-040?
            • orion78fr
              PS4 with BLOD - Getting UART enabled ?
              by orion78fr
              Hi everyone !
              So a friend gave me a ps4 to rescue but it just pulses blue and never boots. I can't get it to safe mode either (maintaining the power button never gives a second beep, except after like 15 seconds to force turn off). Nothing visible on the board and removing the hard drive doesn't change anything (SMART data are OK on PC).
              I'm trying to enable UART on the PS4 to get info on what it stops on, if a memory is bad, something is corrupted... as explained here : https://repair.wiki/w/PS4_UART_Guide
              However, the software that everyone used,...
              07-07-2023, 03:21 PM
            • ns_ripper
              Samsung galaxy s21 exynos (sm-g991B/DS) uart pins
              by ns_ripper
              Can someone help me with a schematic/boardview of this phone?
              I'm looking to identify the rx and tx uart pins on the board.
              Because I want to use the usb-port for power and other things, I can not use the uart over usb method.
              I took some pictures but without the boardview/schematic it's a bit daunting.
              Images:
              https://photos.app.goo.gl/vzYVtVcZgz8trCT48
              I'm uspecting the masked pads above the ufs chip. (but offcourse I'm not sure).
              07-21-2025, 08:49 AM
            • spleenharvester
              Synology MR2200ac mesh router, UART connection - login details?
              by spleenharvester
              This particular unit powers up, LEDs behave normally, but broadcasts no SSID, will not mesh with any other routers. Plugging in an ethernet cable from a Windows laptop results in "unidentified network" with an autoconfigured IP address and no response to pinging 192.168.1.1.
              I was able to log into serial/UART by connecting the 6-pin header to the GPIO on a Raspberry Pi Zero W (GND to GND, TxD to RxD, RxD to TxD, no connection between +3.3V as it is supplied on both sides) using Minicom, command:
              Code:
              sudo minicom --baudrate 115200 --device /dev/ttyS0
              09-02-2024, 01:19 PM
            • Wompatti-
              Ps5 edm-020 3sec BLOD
              by Wompatti-
              I have a ps5 with blue light flashing about three seconds when I press the power button and then it turns of. Second press, only beeb but nothing else. Third press, 3sec blod etc...
              BUT the weird part is if I unplug the power cord and put it back, the console will start without pressing the power button and give that 3sec blod.
              UART shows error code 80800024 and nothing else. There are no cracks on the apu. No shorts on the board that I can find. All standby rails are present and all power on rail will show up for that 3second period. I've tested with two different psu and reflashed...
              08-19-2025, 11:44 AM
            • Guest
              PS4 no power after enabling UART
              by Guest
              Hi, I have a PS4 Slim that shows no power after I tried to enable UART.
              Before this it was working fine except for the disc drive.
              I removed the NOR flash, patched the dump to enable UART and put it back on the motherboard.
              After this process the PS4 acts like there's no power. I tried the power button, inserting a disc and using the joypad. No beeps/no leds.
              It was my first time attempting this so I'm afraid I broke something on the motherboard while using the hot air station, but I can't see any obvious problem or missing component.
              • I checked
              09-07-2023, 05:42 PM
