PS3 Slim - CECH 200X - Capacitors check
  • dedalo101
    • Jun 2016
    • 21
    • Italy
    I would to fix my ps3 slim which has many issues (not related to CPU or GPU); before digging into these issues I would to check the capacitors all around the motherboard; I have read that testing capacitors with the continuity check could results in a false positive reading: could someone tell me which is the correct ohm value that should I read on the tester?
    Thanks!
    • Jul 2011
    • 6057
    Re: PS3 Slim - CECH 200X - Capacitors check
    You need a ESR capacitor tester to do this not a volt ohm meter
    Or just replace all the capacitors that a UF less than 100
    To start with or just replace all the capacitors to be on the safe side but you would also need to do this with the power supply as well
    • dedalo101
      • Jun 2016
      • 21
      • Italy
      do I have to buy a specific model or can I buy the cheapest one?
      For instance, is this ok?
      https://www.amazon.com/KKmoon-Precis...770595&sr=8-92
        • Jul 2011
        • 6057
        You would be better off buying this type
        https://www.amazon.com/Signstek-MESR..._t3_B077JMYW6K
        This is what you are looking for when buying a ESR meter
        For a ESR meter
        “ Using true 100 KHz sine wave to measure the ESR value, which is equal to the testing method of capacitor manufacturer. “
        Now if you want to read the UF value then the you selected would work for this purpose
        • dedalo101
          • Jun 2016
          • 21
          • Italy
          Clear explanation, thanks; however is there something cheaper? I am a rookie and I would prefer not to spent too much at least without any experience in this kind of works. If there isn't an alternative I would buy it from aliexpress because is cheaper.
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            Yes you can look at the project called "Transistor Tester"
            There are a couple of kit versions if you prefer to solder it yourself.
            And some premade ones that are surprisingly good.
            This is all based on an open source project: and so you can reflash the firmware to gain additional functionality.
            The Chinese manufacturers just "steal" the open source firmware and call it their own with no links back to the project, just FYI.
            Here are some eBay links, IMPORTANT, I do absolutely not endorse any of these, please select a seller you prefer and look up their feedback etc!!!
            Most feature rich with Atmega 644: https://www.ebay.com/itm/M644-Transi...3/203041721905
            Standard kit version with Atmega 328: https://www.ebay.com/itm/M328-LCD-12...r/201481944845
            A seller that has many different variants: https://www.ebay.com/itm/M328-LCD-12...r/201481944845
            Bside ESR02 with nice case: https://www.ebay.com/itm/BSIDE-ESR02...r/402358667978
            Some links about firmware upgrades:
            https://www.badcaps.net/forum/showthread.php?t=50720
            https://www.eevblog.com/forum/testge...14/#msg3039314
            https://www.mikrocontroller.net/topic/248078
              master hoarder
              • May 2008
              • 12175
              Also, regarding the PS3 capacitors: generally PS3's use Tantalum, Ceramic, a few solid polymer electrolytic ones, and of course the well-known (as problematic) NEC/Tokin Prodlizer caps.
              So in short, if you have any NEC/Tokin caps, don't even bother getting an ESR meter - just replace those caps on sight. It seems like it really is a matter of -when- they will fail rather than -IF-. By the time I learned this, I stopped doing console repairs. However, I hear people usually replace those with just large-value Tantalums and/or SMD solid polymer electrolytics. Just have a look around badcaps for the NEC/Tokin caps, and you will see what people have used.
              • dedalo101
                • Jun 2016
                • 21
                • Italy
                @Per Hansson
                ok I will take a look to these alternatives based on ATMega; Could I add probes? I mean, are they working with probes and can I check components directly on the motherboard without desolder them (which is pretty impossible)?
                @momaka
                I suppose NEC/tokin components are not the main issue in my case. Anyway I keep your advice in mind.
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  Originally posted by dedalo101
                  @Per Hansson
                  In circuit ESR measurements are pretty much pointless.
                  It requires that you know the circuit really well to be useful.
                  And if several caps are in parallel like is often the case, then in circuit measurements are always pointless.
                  But to answer the questions: yes there is an in circuit test mode in the firmware.
                  And you can calibrate the unit with cables/probes (cables resistance have to be taken into account via calibration).
                  The M-firmware will even allow two different calibrations: one for probes and the other for the test socket.
                  • dedalo101
                    • Jun 2016
                    • 21
                    • Italy
                    I have already heard that in circuits measurements is pointless without the motherboard scheme... but desoldering each component is clearly not the way to follow... is impossible to desolder each component when I do not know where the issue is/are. I have an idea where it is / they could be but I also I cannot exclude that other parts and related components could have been damaged. So my idea was to identify at least the areas around the motherboard which could have issue and then going deeper (in ways which I don't know now).
                    • SoulFreeze
                      Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
                      by SoulFreeze
                      Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
                      After repairing the above issue, I realized the following remaining problem,
                      Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
                      The computer recognizes headphones are connected and displays a popup in windows
                      Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
                      06-21-2025, 09:53 AM
                      SHUTTLE XPC slim DX30 XPC slim J3355 Specification for Upgrade or Repair
                      This specification for the SHUTTLE XPC slim DX30 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC slim DX30 boardview and XPC slim DX30 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for SHUTTLE...
                      09-12-2024, 03:30 PM
                      HP Slim Desktop S01-aF0011ns Slim Desktop J4005 Specification for Upgrade or Repair
                      This specification for the HP Slim Desktop S01-aF0011ns can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-aF0011ns boardview and Slim Desktop S01-aF0011ns schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-12-2024, 03:28 PM
                      SHUTTLE XPC slim DH110 XPC slim i5-7400 Specification for Upgrade or Repair
                      This specification for the SHUTTLE XPC slim DH110 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC slim DH110 boardview and XPC slim DH110 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                      HP Slim Desktop S01-pF0127d Slim Desktop i3-9100 Specification for Upgrade or Repair
                      This specification for the HP Slim Desktop S01-pF0127d can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-pF0127d boardview and Slim Desktop S01-pF0127d schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
