Macbook A1466 - Long to wake from sleep after motherboard swap
  • orion78fr
    • Apr 2022
    • 37
    • France
    I don't know if it's the correct forum for this but I hope so.
    So, it's the continuation of https://www.badcaps.net/forum/showthread.php?t=115802, I swapped the motherboard to a "working" second-hand one.
    Now, I have weird issues with it. It works mostly fine (can boot, and everything seems to work) but every time I close the lid, even for 1 second, it takes a very long time to wake up, like between 30s and 1 min, instead of the normal .5s.
    The weird thing is that in safe mode (booting with left shift pressed), it works fine. I tried to see what could do that in "EtreCheckPro", but the only difference I see is the zoom daemon (which I uninstalled) and the chrome update daemon (https://pastebin.com/C2p53Daf & https://pastebin.com/j90qG31V in safe mode, excuse me for the french in the logs).
    Another weird behaviour is that network recovery (cmd + alt + R) fails after downloads with a 5101F error code, and the original version network recovery (cmd + alt + shift + R) just hangs after loading (downloads works fine, but second progress bar fills very slowly and hangs full, had let it load all night but nothing happens).
    I don't know much about macs so I don't really know where to search.
    Edit : note that with a brand new session it does the same, but on initial boot before opening a session, it works correctly.
  • orion78fr
    • Apr 2022
    • 37
    • France
    Re: Macbook A1466 - Long to wake from sleep after motherboard swap
    Okay so, I solved my problem ! (while severely sleep depraving myself ^^" 5AM at the moment of writing)
    So, I'm now 99% sure the problem was the EFI version on the new board was way too old to be compatible with the newest system version that was installed. As these updates are automagically installed when system is updated, Apple doesn't provide any easy way to update EFI or SMC versions.
    I did an `/usr/libexec/firmwarecheckers/eficheck/eficheck --integrity-check` and got a message about my EFI version not being in the allowlist, so I knew I didn't have the latest version.
    Downloaded a macos update and extracted it (took the one I found in another forum post : https://support.apple.com/kb/DL2088).
    To extract the interesting part, double click on the .dmg, copy the contained .pkg somewhere, then use `xar -xf <...>.pkg FirmwareUpdate.pkg`
    then `cd FirmwareUpdate.pkg && tar -xf Scripts`.
    Once we're here, we can flash the SMC and some other things (like usbc firmware) with `sudo /usr/libexec/FirmwareUpdateLauncher -p "$PWD/Tools"`. Should say at the end if something updated.
    Then flash the EFI with `sudo /usr/libexec/efiupdater -p "$PWD/Tools/EFIPayloads"`. It should say at the end "reboot to apply the update". Mine said it updated EFI from 176.00 to 428.60.3 !
    Rebooted, had an apple logo on black background with a progress bar, it rebooted, and now sleep works correctly and recovery mode doesn't crash anymore !
    Hope this could help someone in the future.
    • reformatt
      • Feb 2020
      • 1437
      Nice one, command line stuff always handy. You can also determine firmware version by going into Finder, About This Mac, System Report.
      The problem using command line stuff for this is that you have to get into MAC OS first, rather than doing via the recovery console. Very old firmware versions won't boot APFS file systems so you are stuck there, and others don't recognise 3rd party SSD's. It's amazing how many people don't update, and some are still on Yosemite.
      So for really old boards that aren't APFS aware, the best way is to use either Big Sur (for 820-3437) or Monterey (for 820-00165) installers with a spare Apple SSD. Format it as MAC OS Journalled (if you use APFS it'll complain that you can't install it without a firmware update). Then install MAC OS in the usual way. Firmware is updated as part of the install process automatically. Once it gets to the final stage of installation (where it says about 30 mins remaining), no need to complete that. The firmware should've already been updated and you can put any old drive in from that point. You'll also find at the end your SSD has been auto updated to APFS too.
      As a footnote, newer versions of MAC OS have the OS in a separate APFS container to that of the user data. They have a software integrity feature called the seal that detects if any tampering has occurred. IIRC, you actually boot off an image of the OS, not the actual files. Reinstallation is very risk free, and doesn't touch the user APFS container. Can't see how any 3rd party (virus or malware) could alter the OS without it being detected. Apple do have some great stuff in this way and light years ahead of Windows.
      • orion78fr
        • Apr 2022
        • 37
        • France
        Yes, but also no. The system report was telling me EFI was "MBA71.0176.B00" and is now "428.60.3.0.0", two vastly different numbering scheme. Plus I didn't find any official documentation on what the current version is (and couldn't compare it either to the "430.140.3.0.0" I found somewhere on the net).
        The problem I had is that no recovery option (cmd + R, cmd + alt + R and cmd + alt + shift + R) booted in my case, it either errored out with an 5101F or hanged while loading (which is fixed now that the EFI is updated). Don't know if an USB bootable device would have worked or just hang like the other recovery options.
        Another solution I found on internet, if recovery worked, was to install macOS on an external USB device. That would have updated the EFI during the install.
        Oh yeah, would have been great, but didn't want to risk the user data and didn't have any spare mac drive at hand.
        By the way, on windows, when you reinstall over the main partition, all user data is copied under a windows.old folder at the root (you have to choose custom install and point to the correct partition IIRC), which is handy if you can't boot the device (but I would recommend a copy by extracting the disk anyway, I can't trust any of these reinstalls to safely handle my data).
        • reformatt
          • Feb 2020
          • 1437
          Built in recovery doesn't work on the really old firmware, that's why you create a bootable installer on USB. If you work on these regularly like I do, then something like MBA71.0176.B00 is considered at least pre-High Sierra. I know that new numbering scheme started from at least that version (think it was 195.0.0.0 or similar).
          820-00165 boards are at 476.0.0.0 for Monterey 12.6.3.
          • orion78fr
            • Apr 2022
            • 37
            • France
            Oh I see, I kinda assumed the included internet recovery was a failsafe way to reinstall because it would download what it needs to work, like a recent bootable USB directly downloaded "in memory".
            • reformatt
              • Feb 2020
              • 1437
              Older versions of the recovery console usually default to whatever MAC OS it came with and tries to download it from Apple's servers. If something changes on Apple's end then this no longer works, especially if its an older version they no longer support.
              Hence why I never use it and rely on USB installers. Its like a chicken and egg situation really. Unfortunately on the newer T2 MAC's, this option is disabled by default and a complete PITA if recovery doesn't work for some reason.
              • reformatt
                • Feb 2020
                • 1437
                https://www.badcaps.net/forum/showthread.php?t=117885
                • zeg12345
                  A2141 820-01700-A MacBook Pro (16-inch, 2019) 2.3GHz i9 32GB RAM 1.0TB SSD - Unable to wake from extended sleep
                  by zeg12345
                  If the lid is closed or the system is put into sleep mode for more than 30 minutes or so, then when I try to wake it back up by tapping a key or by tapping the power button I get no response. The device is warm but the CAPS lock light on the keyboard is unresponsive. To get it to reboot and be functional again I have to hold down the power button to force it to power off, then when I press the power button it reboots normally. I erased the system and reinstalled macOS to do a factory reset, and the issue still persists. I replaced the logic board and the issue is resolved with a separate known...
                  03-15-2024, 12:06 PM
                • psdavid65
                  Macbook Air A1466 820-3437-B Booting Problem
                  by psdavid65
                  I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
                  06-20-2024, 12:27 AM
                • dellxps15
                  macbook 820-00163no sleep wake problem
                  by dellxps15
                  hi got this board with a burned hole in the vram zone. owner reflower gpu and cpu for no reason ( he watched online video and think that this method will fix every problem). after find gpu totally shorted, i decided to make it uma.
                  after send it back to owner he told me board was crashing, so i replaced also the 3 cpu mosfet, telling him that if that doesnt fix the crash, i give up on the repair.
                  after replace the 3 mosfet, board was shutting down while loading os, and after asking owner if battery was ok and he told me it was.... i discovered that with another battery pc was booting...
                  04-02-2023, 04:36 AM
                • echothegamer
                  Macbook A1466 dies when charger disconnected
                  by echothegamer
                  Hello all,
                  Working on my wife's 13' Macbook air. It's been in a box since she upgraded but I figured it could be good practice.
                  Details:
                  Macbook 13' A1466
                  Board (820-3209-A)
                  Battery OEM 7.3v 50Wh 6700 mAh (020-7379-A)
                  Pictures below of Boardview and schematic...
                  I don't know how to test the voltage on a MacBook battery. I just assumed it had an enable pin but the best I could read was 300 something mV poking around the battery connector.
                  It's an older model and it is very likely that battery has become...
                  10-28-2023, 12:00 PM
                • dbuergi
                  Macbook A1466 820-00165A heavy water damage but working with "flashing" screen
                  by dbuergi
                  i got a A1466 with serious water damage. I was able to clean the whole board and only found a fuse with a coroded trace. Cleaning and resoldering did the job and the macbook started normal but after some time the screen began "flashing" like turning on and off while the Macbook was still running. I checked the board again but was not able to find the problem until now.
                  Any ideas where to look?...
                  11-07-2024, 10:57 AM
