Macbook A2337 5V
  • Instafixx
    • Jul 2022
    • 374
    • India
    Macbook A2337 5V
    Namaste!
    I have a Macbook A2337 820-02016 stuck at 5V.
    History : Customer plugged in a 3.5MM jack supposedly from a large audio system at an auditorium and the Machine was spot dead.
    PPBUS_AON is cycling from 11.2 to 12.2V.
    Initial checks reveal PP5v_S2 is missing with 0V. No shorts found on this rail but.
    The enable pin P5VS2_EN is also at 0V. I feel its U8100.
    Anyone has an idea regarding this ?
  • Instafixx
    • Jul 2022
    • 374
    • India
    Re: Macbook A2337 5V
    Originally posted by Instafixx
    Namaste!
    Update - Reballed the U8100 - Still the Same.
    Replaced the U8100 from a donor baord. Still the same issue.
    Any guidance will be really helpful.
    • mon2
      • 14499
      Remove F5200 and then check the voltage to ground of PPVBAT_AON_CHGR_REG.
      Post the measurement.
      With the Type C power supply stuck @ 5v means that the CD3217 ACE controllers have a fault. Need to check the local LDO rails on each to see if they are present.
      Same case as all other CD321x controllers that fail to negotiate to 20V power delivery contract...review the repairwiki articles by @Piernov and others on how and when 20V is selected.
      https://www.logi.wiki/index.php?titl...ootup_Sequence
      • Instafixx
        • Jul 2022
        • 374
        • India
        Pin #1 of F5200 after removing has 12.3V
        • mon2
          • 14499
          Is it stable ?
          Remove all power. Meter in resistance mode.
          Check the resistance to ground of downstream side (Pin #2) of the removed fuse @ F5200.
          • Instafixx
            • Jul 2022
            • 374
            • India
            Is it stable ?
            Yes. Its a stable 12.3V.
            Meter in 2K Mode - Red Probe on Ground. Value is .490
            • mon2
              • 14499
              So you have 490 ohms to ground resistance on the downstream / consumer side of this PPBUS_AON power rail. That is a low reading.
              Do you have an adjustable power supply that can support 1 volt (not higher) for voltage injection. Would you have a thermal camera?
              The shorted part may heat up but the resistance may not be low enough for this method but worth testing.
              • Instafixx
                • Jul 2022
                • 374
                • India
                When using another meter and setting it to the Omega Sign. The reading starts at 5.2M and keeps going down. (Held for about a minute at it came till 1.9M and then i stopped).
                Yes i do have a adjustable power supply to inject Voltage.
                Sadly - i dont have a thermal camera.
                But the board in general did not heat up at any particular place - apart from the CPU
                • mon2
                  • 14499
                  So this rail is not shorted.
                  Check the voltage to ground of the CPU power rail. Checking if the CPU is shorted.
                  Also consider to use DIODE mode reading of the same test point.
                  • Instafixx
                    • Jul 2022
                    • 374
                    • India
                    This is an M1 board. Still familiarising with myself. Which rail do i check ?
                    • Instafixx
                      • Jul 2022
                      • 374
                      • India
                      PP0V805_S1_VDD_FIXED at Pin #1 of C7821 is 1.6 Ohms.
                      Do you think its the U7700?
                      • Sacred0489
                        • Sep 2022
                        • 21
                        • Spain
                        Hello i hope you have a great day i have a 820_02016 (a2337) When I connect the usb charger the voltage oscillates between 3 volts then it goes to 5 volts it reaches 20 volts and then the cycle starts again I have checked PPBUS_AON and it has 12.30 volts but it is intermittent while PP3V8_AON_VDDMAIN has 3.8 volts I already used the U301 programmer for this model since I have seen that it could be the problem but nothing, could you help me thanks
                        • jorgea380
                          • Apr 2024
                          • Mexico
                          Hi I have the exact symptoms, did you ever find the problem?
                          • Instafixx
                            • Jul 2022
                            • 374
                            • India
                            Nope. Had to go for a motherboard replacement.
                            • kevingill
                              • Jun 2013
                              • 152
                              • England
                              Just had this fault on a MacBook M1.
                              It was the headphone jack board that was faulty and bringing down the whole board.
                              Unplugged the connector and the MacBook boots.
                              Couldn't see anything obviously wrong with the board, but going to order a replacement headphone jack board.
                              • rounin
                                MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                by rounin
                                I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                                🛠 Original Issue
                                The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                                ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                04-19-2025, 01:18 AM
                              • mkdj
                                MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
                                by mkdj
                                About me, my goal and the equipment I (don't) have:
                                I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
                                About my issue and my goal:
                                A friend of mine has a MacBook Air M1 A2337 that does not...
                                04-03-2025, 08:28 AM
                              • Adogabriel100
                                where to get trusted CD3217. Problem with A2337 Macbook Air
                                by Adogabriel100
                                Hey! As the title says. i don't know if this is the right place to ask but i need to get trusted USB C Controllers (CD3217-CD3215) For macs and dont know where to get them. i dont know if you guys know where is a good place to get it.
                                The thing is that i have a Macbook air A2337 M1 and i dont have a donnor board to get the CD3217. So i try the CD3217 from a A2141 Board and at first, whitout his eprom it does not convert 5v to 20v. then i put the original CD3217 eprom from the A2141 and then the macbook A2337 conver the 5v to 20v but still not turning on. i guess that the CD3217 is...
                                09-06-2024, 12:06 PM
                              • Skrndelj
                                Apple Macbook Air M1 A2337 Trackpad problem
                                by Skrndelj
                                Hello all,
                                I am repairing a Macbook A2337 and i have a problem
                                The Macbook is stuck in restore as someone before me tried a DFU restore and bricked the device, now i can't do a restore as AC2 throws error 1 which is related to the trackpad.
                                When i turn on the device i get the trackpad click for a few moments and then nothing, i tried 7 trackpads and 7 trackpad flats, i know all 7 are functioning okay, especially one as i use it for testing and DFU restore.
                                I inspected the whole board and everything seems fine.
                                Can anyone help me as i didn't fiddle with trackpad...
                                06-11-2024, 04:26 AM
                              • slimmy182
                                MacBook Air M1 A2337 820-02016 not booting, taking 5V 0.42A and 2.173W
                                by slimmy182
                                Hello, a friend give me this M1 Mac Air, he said that it simply stop working. Apple preventive is replacing motherboard.
                                Model is MacBook Air M1 A2337, logic 820-02016, not booting, and taking 5V 0.42A and consuming 2.173W.
                                Once disassembled is very clean, no water damage at all. Visual ispection reveal no visible problem. Flir camera point to two hot point:
                                C81DC PP3V8_AON_VDDMAIN
                                And
                                Q5800
                                What should I test as next step?
                                Thank you very much!
                                02-01-2024, 01:08 PM
