Razer Blade 15” Advanced (2021) | RZ09-0409x / Won't run on battery.
    The laptop runs perfectly fine on the AC adapter but won't run on the battery. Precise symptoms:
    1. When attempting to turn the machine ON with AC adapter unplugged laptop would fire up (fan spin, keyboard backlight, green led) to a black screen and turn off after about 30 sec. The laptop does react to holding the power button and it turns off after 10 sec of holding the button.
    2. Once running off AC adapter and logged in to Windows, when I remove the AC adapter from the charging port laptop would continue to run for another 40 sec and then switch off suddenly. During these 40 secs, I would notice Windows freezing and running slowly. The system interrupts process would occupy a significant amount of available computing power. Most of the time battery icon in the tray fails to switch into battery mode (so AC plug icon is visible in the Windows system tray despite the AC adapter being unplugged).
    3. After rebooting back to Windows (on AC adapter plugged in) Event Viewer would report the following error seconds before the sudden shutdown: "The embedded controller (EC) did not respond within the specified timeout period. This may indicate that there is an error in the EC hardware or firmware(..)"
    What has been done so far to resolve the problem:
    1. I have programmed a clean ME Region BIOS in version 1.09. No fix.
    2. I have programmed fresh EC BIOS (8mb). No fix.
    3. Tried on a different battery. No fix.
    4. I have found one 2R2 resistor around AC Power MOSFETs measuring 100k. Replaced. No fix.
    What my plans are:
    1. Replace the power management chip: ISL95520AHRZ.
    2. If the above does not help I think the last suspect would be the KBC/EC chip IT8320VG.
    My questions:
    1. Do you think anything else except for the ISL95520AHRZ or IT8320VG could be causing the issue?
    2. If it comes to replacing IT8320VG - does it need to be programmed? There is an 8 MB EC bios chip on the board so my guess is the EC chip code is stored outside of the EC chip itself.
    3. If it comes to replacing IT8320VG - I have only found replacements available on aliexpress and ebay, all from China. How trustworthy these chips are? I am worrying that the current working(or at least partially working) EC chip could die completely during desoldering and then I would struggle to find a working replacement.
    Thank you.
    Re: Razer Blade 15” Advanced (2021) | RZ09-0409x / Won't run on battery.
    Hi!
    I have problem with same laptop.
    You said you re-programmed EC firmware.
    Can you share it please ?
    I cant find EC firmware bin. file.
    On makres page have main bios only.
