This laptop model is HP ENVY x360 Laptop - 15m-ed0013dx (9HP23UA)
It died one day and wouldn't start, all lights out. The charging light on the side is out with charger plugged in (tested output, good charger).
I took the cover off and disconnected the internal battery and reconnected it. After doing so, I could start the computer up to a blue BIOS screen about BIOS being corrupt (from disconnecting the battery I presume) and after hitting enter, back into windows; everything working. The charging light will light if I plug in the charger (red while charging/whitish blue when fully charged). If I do a shutdown, the charging light goes out and then you cannot start it again without unplugging and re-plugging the battery and repeating the above process.
I have done the diagnostic tests that are in the startup menu. I get a message about a possibly bad AC adapter, but it's not bad and I have a brand new one from a newer computer that gives me that same message (but works fine on the brand new laptop). The battery test shows that the battery is good, but it can't read the battery status. I posted asking for a schematic (no response yet), so I can figure out what is wrong with this laptop (maybe power management chip?), but in the meantime, I ordered another battery from Amazon to rule out the battery. It comes on Monday (god willing).
If anyone has had a similar problem, I'd love to hear what you've found.
Thanks,
JJ
Thanks,
JJ
