Data Recovery Question PCIe Samsung Apple SSD
  • ugamazing
    • Jun 2013
    • 171
    • usa
    Working on a data-recovery job on a 2017 Apple/Samsung PCIe blade SSD (from 2017 A1466). Cause of failure of the drive is a shorted controller (S4LN058A01-8030). I am now wondering what the best option to move forward with this one is, and had some questions to anyone who may know more about this:
    1. I have a TON of dead SSDs with the same controller IC (S4LN058A01-8030), but I do believe the firmware version is important. Is this correct?
    2. When removing the shorted/bad controller, I found the undercoat on the drive PCB was very, very thin and came off VERY EASILY, to the point where I had to apply an entirely-new layer of conformal coat and then scrape away the pads. I'm curious if this thin overcoat may be responsible for the shorting, but I have no schematics or board view fie for the drive, so I can't easily confirm. I plan to try a re-ball of the original controller first, and if that doesn't work, try a different controller. Does anyone know if a board view or schematic for these blade drives exists?
    3. Should any controller of the same part number (S4LN058A01-8030) work, or will firmware variances affect functionality? Don't need the drive to work long-term, just well enough to pull the data.
    Any insight will be appreciated!
  • resistor83
    • Oct 2018
    • 127
    • Italy
    hi, I have the same problem as you,
    the samsung chip heats up and I can't see anything
    you solved?
    I only saw a video on YouTube where they tried to heat that chip​
    • a_p3rson
      Apple Watch Charging Controller Schematics / Boardview - 820-02601
      by a_p3rson
      Hi there,
      I'm looking for anyone who might have information on Apple's embedded Apple Watch charging daughterboard, ID 820-02601. This is currently used by Anker in their Apple Watch charging products, but likely by other Apple partner brands as well.
      You can see the board referenced in ChargerLab's teardown of the Anker Y1811 3-in-1 MagSafe cube - they discuss the "Apple Watch wireless charging circuit" about 2/3rds down the page. It's not pictured, but the board ID reads 820-02601-A, which sure sounds like Apple.
      This daughterboard uses an interesting...
      04-21-2025, 11:41 PM
    • reformatt
      Intel iMacs, 3rd party SSD failures and Fusion setups
      by reformatt
      I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
      As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
      So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
      12-18-2024, 10:34 PM
    • Deeloc
      How to flash SSD 1tb WALRAM controller SM2259XT2G flash samsung NAND V6
      by Deeloc
      I have a 1tb WALRAM SSD (Photo)
      Controller SM2259XT2G (photo)
      Samsung memory (photo):
      Part Number K9DVGB8J1B DCK0
      Name V-NAND V6
      Type TLC
      The SSD itself is detected as 1gb, but is not initialized.
      There is a Sata to USB adapter
      A lot of SMI MPTool, did not flash it. compare flash fail (17)
      K9DVGB8J1B is not listed anywhere
      What to flash?​...
      06-05-2024, 08:32 AM
      09-07-2024, 05:50 AM
    • master3112
      ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
      by master3112
      I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
      When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
      10-29-2024, 09:32 PM
