HP 6730S very strange problem
  • rivette65
    • May 2008
    • 12
    hi i have a big strange problem with a laptop of a customer
    it's an hp 6730S
    it hangs at the HP logo with the message “press the esc key …..”
    when i press the esc or any key nothing happen . it hangs there
    i ‘m an electronic engeneer specialised in laptop repair ! so i have programmed the eeprom but the problem is the same . dismounted the laptop ,changed the processor , the memory , changed a new eeprom chip but the problem is the same.i have changed the chipset too.
    so i decided to reboot the laptop , to press the esc key and to wait . after 40 min it goes to the setup . i have tried every thing there but after rebooting the same thing happend and must wait for 40 min again to see it going to setup . i putted a virtual windows on a cd and after 40 min it boots on it and begins to load windows but veryyyyyyyyy veryyyyyyy slowly until it rises the windows desk …
    strange problem.
    now i have 2 HP6730S with the same problem
    can someone help me ?
  • port27374
    • Sep 2010
    • 7
    Re: HP 6730S very strange problem
    Have you tried swapping out the hard drive and CD rom?...
    If this still doesnt work with new HDD - then you should also try to bench the board with nothing attached, except the RAM, CPU, Keyboard and Screen.
    You should also treat the keyboard as suspect incase it is faulty and sending some incorrect signals to the board, so remove it and try to boot the machine again...
    please report back with findings if at all possible...
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      Maybe its overheating and downclocking the cpu ery low?
      • rivette65
        • May 2008
        • 12
        i'm working with only the motherboard on my desk without nothing attached . only an external keyboard and monitor
        • Orpheous
          • Oct 2010
          • 43
          Sounds like a dead/dying hard drive to me. Swap out the SATA HD and try an OS re-install from scratch.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            I agree.
            A dud HDD is a definite possibility.
            A dud drive and no drive can throw the same symptoms.
            Try it on the desk with a known good drive.
            Mann-Made Global Warming.
            - Dr Seuss
            • Woodsworth
              PS3 CECHC03 60GB YLOD Troubleshooting
              by Woodsworth
              I have a post on psx-place for this but thought I'd try here as well in case anyone has experience or the schematics or any kind of help. Here's the original post from psx-place:
              START
              Hi, so I bought a YLOD Fat PS3 as I wanted a repair project and thought it would be a good way to get experience. I was able to solder to the RX, TX and Diag pads on the COK-002 motherboard and was able to get external access and retrieved the codes. I haven't powered it on beforehand so these should be the last ones. I did try to get internal access immediately after but kept getting scopen response...
              03-19-2024, 07:58 AM
            • theone111
              by theone111
              3. Problem: TV shuts down
              07-22-2024, 10:36 AM
            • Stunt
              Hp Laptop Stuck on Hp protected by hp sure start screen
              by Stunt
              Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
              I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
              I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
              Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
              screen that's it and stuck there. I left it until the following day and i still...
              09-02-2025, 01:51 PM
            • pkslowk
              Debug Card Error Code and Solution
              by pkslowk
              Sr. Motherboard Debug Error Code Solution
              1 Intel 845 E9 Bios Related Problem
              2 Intel 845 D4 CPU Socket Related problem
              3 Intel 845 37 Bios Related Problem
              4 Intel 845 7C Bios Related Problem
              5 Intel 945GCPE 34 Bios Related Problem
              6 Gigabyte 845 2 Ram Related Problem
              7 IBM Server A6 A7 Ram Mismatch Problem
              8 Asus 845 29 CPU Related Problem
              9 Lenovo I946 97 C-Mos Jumper related
              10 Gigabyte 845 A0 CPU Related Problem
              11 Asrock G31M-VS D7 Bios Related Problem
              12 Compaq 845 BD-70G B0 CPU Socket Related problem...
              01-28-2021, 12:51 PM
            • Zeonalbasta
              Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
              by Zeonalbasta
              i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
              The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
              09-13-2024, 01:17 PM
