Macbook pro 820-00928-A Power but no Image
  • Comp_Pro
    • Jun 2020
    • 33
    Hello all,
    I have this macbook pro board number 820-00928 which appears to power on fine and charge the battery but does not show any other signs of life. I can see the fans spinning and the heatsink get hot. Most of the coils on the board have voltage except for PPVCCGT_CPU_PH1 and PPVCCGT_CPU_PH2 as well as P5VUSBCT_LL. There is no chime, no caps lock light, no nothing.
    Something very peculiar is that with the battery disconnected, the motherboard is drawing a steady 1.31Amps at all times. It is not showing typical fluctuations as one would expect. I attempted DFU restore but it will not show in configurator 2. I will be inspecting further.
    Has anyone come across this issue?
  • mon2
    • 14677
    Re: Macbook pro 820-00928-A Power but no Image
    Static current draw could mean a shorted cap or another component.
    Remove all power. Meter in resistance mode. Measure the resistance to ground at each and every coil. Each coil is linked to a buck regulator that accepts a higher input voltage and lowers it to another voltage.
    A low resistance could be due to a shorted part.
    • reformatt
      • Feb 2020
      • 1510
      At face value, sounds like a damaged CPU. Common on these models is liquid damage to the LCD connector or the CPU VRM's. In my experience, Vcore present with no CPU activity with this high current is normally indicative of a damaged CPU.
      Check the LCD connector both ends for any liquid damage. Crap design with 50V backlight leaking into the adjacent EDP data line pin to the CPU. Have one here last week where the CPU still works, but the EDP line is shorted to ground (and thus no image on the LCD but works external via USB-C/HDMI). I would have expected the CPU to be dead, but this one survived. Maybe because one of the USB-C controllers had a shorted cap on it as well.
      • piernov
        • Jan 2016
        • 4439
        • France
        No T2, no DFU restore. Regular SPI ROM for UEFI on this board.
        • SarcasticOP
          General question about MacBook power rails for repair.
          by SarcasticOP
          I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
          • PPBUS_G3H (12.6V-12.8V)
            • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
          • PP3V42_G3H (3.42V)
            • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
          • PPVRTC_G3H (3.3V)
            • This
          12-12-2024, 05:50 PM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
          03-31-2024, 02:12 PM
        • kitor
          Dell Latitude 7390 - all power rails up except VCC_GT, no image.
          by kitor
          I have Dell 7390, LA-F311P.
          AFAIK there's no schematics available, but there's one for LA-F312P in this thread. It differs in no Thunderbolt controller (iirc that's for 5290/5390), however rest of the schematics/BV seems to match 1:1.
          Behavior:
          Connected barrel plug, no RAM:
          - power LED turns on + orange light on front
          - turns off after a second or two
          Connected barrel plug, with RAM:
          - power led turns on + while light on front
          - after a few seconds power led turns off, white light...
          07-26-2022, 09:53 AM
          09-06-2024, 05:59 AM
