Lenovo ideapad 330-15AST - no backlight on battery
  • xos
    • May 2023
    • Czech
    Hi,i need some advice to fix this laptop. Laptop was spilled by water, cleaned and runs normally about 1 year, but now its no backlight on LCD, but when connenet AC adapter runs well with backlight. Battery was replaced with new one but problem presist.
    +LEDVDD ON ac 19,4V
    +LEDVDD ON BATTERY 7,5V
    [MOD EDIT]
    Link to schematic - https://www.badcaps.net/forum/showthread.php?t=116545
    Thanks for help.
  • mon2
    • 14636
    Re: Lenovo ideapad 330-15AST - no backlight on battery
    With only the battery - can you see the graphics on the LCD? Use a phone in torch mode to shine on the front face of the LCD to confirm. Otherwise, the LCD is off.
    Sounds like the issue may be with the LCD screen and its internal LED power supply.
    What is the voltage to ground of INVT_PWM signal on the LCD connector with the power adapter? With only the battery ?
    • xos
      • May 2023
      • Czech
      Forgot mention that picture is present but only backlight is not on battery. And voltage on INVT_PWM is 3,10V on battery and same for AC adapter.
      • mon2
        • 14636
        Good. Remove all power. Meter in lowest resistance scale. What is the resistace across R22 on the logic board? This should be ideally ~0 ohms.
        Comment: Based on your shared measurements, to me it appears the issue is inside the LEDVDD rail of the display. I can see a 'hack' solution which is to remove R22 and insert instead a voltage boost board (should be very low cost) to accept the battery voltage of ~8 volts and boost it to ~19 volts to feed on the other side of the removed R22 component.
        The LED backlight current is usually very low. It is only an idea but since the adapter ~19v feed on LEDVDD works but the ~8 volt from battery does not, yet the display is not defective for the graphics - only the backlight circuit is of concern.
        • ferah831208
          by ferah831208
          03-18-2025, 01:18 AM
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • jared101
          Lenovo Ideapad 320-15IKA NM-B452 not charging battery
          by jared101
          NM-B452
          Hi guys. I've used the forum a lot but never asked questions before. I had a Lenovo come in that was shorted on the 20V rail. I fixed that and thought my job was done until I realized it wasn't charging the battery. Here is what I've checked so far
          On the BQ24780SRUYR charging ic
          VCC 20V
          SMBUS lines
          SDA 3.3V
          SCL 3.3V
          Current Sensing lines
          ACP/ACN 2.3 ohms
          SRP/SRN 21.2 ohms
          REGEN line 6V
          PHASE .84V with no battery installed(this may be normal)
          08-03-2022, 09:19 PM
        • ahmarzo
          Lenovo IdeaPad 330s no display on battery
          by ahmarzo
          Have lenovo IdeaPad 330s with motherboard part no 330s_kbl_v09.the laptop works fine on adapter and the battery charges fine .but when powered through battery power stays for 1-2 seconds and shutdown.have changed the charging ic and bq24780s and tried another working battery
          When power button is pressed on battery 3v and 5 v comes and goes and all voltages are present for 1-2 seconds.
          Help me solve this problem here is the link for schematic https://www.badcaps.net/filedata/fetch?id=3230319.
          02-13-2025, 10:26 AM
        • code share
          Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
          by code share
          I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
          Here's what I've tried so far:
          • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
          • Booted successfully on AC power only with the battery disconnected
          • Visual inspection of the battery — no swelling, burn marks, or connector damage
          • Battery
          04-21-2025, 12:50 PM
