Fan-Hax Inc
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Fan-Hax Inc
    For some reason, some people on a local electronics forum got the idea that i do reballs. I only reflow, i don't have the equipment to change the solder balls. I used to send them to a guy i know, but since i got burned with my own dv9000, i no longer recommend him.
    Now, i got a message about a tx1000 with nvidia 6150. Goes black when heats up, and starts up again only if it's allowed to cool. Guy bought it from an auction or something, as the touchscreen needs to be replaced, and he told me he opened it up to find a coin (!!!) between the 6150 and heatsink. Now that's ugly... especially since our pennies are made from an alloy with a crap thermal transfer coefficient.
    I told him i can only inject flux under the chip, reflow it, and make an aluminum shim for it, and that it's likely to need a fan mod as well to make it react to the GPU/NB temperature as well, not just the CPU. Now, i've had this idea for a while but never gotten around to trying it out.
    As you know i've modded my dv9000 with an extra fan over the GPU, but it's been bugging me for a while that while the tiny 30mm fan i used there is whining away, the main fan stays lazy because it's only dependent on CPU temp. Since the fans in these things are 4-pin, accepting a PWM control signal, it's fairly trivial to design a circuit to take input from a couple thermistors placed on the heatsink, one near the GPU, one near the CPU, and make it into a PWM signal, hijacking the control line of the fan.
    The beauty of it is that the fan is still powered from the same place, also the sense line remains there, so the computer won't know the difference, and the result is OS-independent and does not require ugly patches like fooling the temperatures in the DSDT and such, as seen elsewhere.
    I will not make an attempt to linearize the thermistors as their resistance vs temperature curve is advantageous here - i need the fan to stay as quiet as possible below 50C, but do its best so 60C temperature is not exceeded. I've calculated the thermistors to provide maximum input voltage to the controller at 55C for the GPU, and 65C for the CPU. I will be using a MC34063 SMD for my PWM control, and by the looks of it, it won't need much extra parts. Two resistors for each input (just because i can't find exact values), another resistor for the output, two diodes for summing, a few ceramic caps and of course, the thermistors. That's all.
    Told him to come on Monday, so that'll be plenty of time to tune the design.
    A working TV? How boring!
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5046
    • US
    Re: Fan-Hax Inc
    ugh I hate you and your fucking genius
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      Re: Fan-Hax Inc
      If you got time, maybe post a few pics when you're done. I'm sure a lot of people will find this mod useful. My Dell C600 laptop could probably use one too. That thing runs hot until its whole bottom burns. Of course it's a Pentium 3 laptop with leaded solder and has been running that way for some 10 years now. Probably wouldn't mind to run another 10 the way it is. But still, I'd like to keep it a bit cooler.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        Re: Fan-Hax Inc
        @ momaka: The circuit i am designing is for 4-wire fans. Older laptops are likely to have 3-wire fans, for which you can use a very simple circuit with one transistor, one resistor and one NTC thermistor, ala the fan controller you see in cheap power supplies.
        The guy with the tx1000 came Monday but i didn't have time to do the board by then, so i just reflowed it and cut the PWM wire on the fan (which made it run at 100% because there's an internal pullup resistor). He's coming back on Friday to get the controller board fitted. And there will likely be some extra holes drilled in the case, as the thermal design of that tablet is just atrocious. Even with the fan blaring at full throttle, load temperatures were in the high 60s. That's better than having the fan only reach full speed at 85C, but if that thing is to last any reasonable amount of time, something needs to be done about it.
        Anyway, here's a sample of Fan-Hax rev. 1. I realized the MC34063 wouldn't work, as it is variable-frequency, and the fan in this tablet adhered to the intel standard of 25kHz (even tho it's an AMD based machine). I believe most of them use this fixed frequency standard. So i used another circuit which i've built before for the same application, only this time i made it smaller. It's the 2nd circuit on this page: http://www.4qdtec.com/pwmmod.html only with slightly different values.
        It uses all jellybean parts, and the PCB is designed to be easily hand soldered. In fact, i could have made it smaller and still be easy to build, but i thought it's enough. You can make 4 of them on a 100mm wide PCB. It's got one SOIC-8 and all passives are in 0805. Well, in my case one resistor is 0603 because they didn't have 0805 in stock but that's a different matter. There's one ugly jumper wire but i couldn't be bothered to shuffle the component placements again. For now, one thermistor input only, as that's all the tx1000's gonna need. PCB for 2 inputs soon to follow.
        I have tested this board i just built and it read as follows:
        PWM frequency: 22.8kHz. Intel says 21-28 is okay, so this oughta do.
        Duty cycle: 40% to 100%, from 30 to 55C. I would have liked a lower limit of say 10%, but since the laptops this is designed to fit in have poor cooling anyway, it's likely that the fan would never go this low even if it did have the range. Either way, at 25C it's likely around 30% - but it's too hot in here to be able to test that.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          Re: Fan-Hax Inc
          I wasn't entirely happy with 40% minimum, so i found a way to get a wider duty cycle variation for the same temperature range. Since what it did is it "bent" the ramp waveform, it sorta compensated for the nonlinear characteristic of the thermistor as well, so i now have a pretty nice PWM fan controller, even if i say so myself.
          Minimum should be around 20% at 25C, lowest i could measure right now is at 29C, where the duty cycle sits just a smidge over 25%. It reaches 50% at 41C, and it's at full blast at 53C. Frequency sits now at 24.96kHz, it doesn't get much closer than this. We'll see how it fares tomorrow.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            Re: Fan-Hax Inc
            The first Fan-Hax board was installed today.
            Not in the tx1000 as that guy has yet to show up again, but in an Acer. I forgot the model name, will update... I was too busy soldering and taping stuff to remember that. All i remember right now is it had an i7 with turbo boost and a GT500 series GPU. The thing would reach 105C when gaming and shut down, and the fan never even got close to 100%... Owner told me the only time he really heard the fan was when flashing the BIOS. To keep it from reaching shutdown temperature he had to disable turbo boost on the CPU and underclock the GPU. Good job Acer.
            I hadn't bothered updating the boards yet, so i just hooked both thermistors up in parallel, and adjusted the voltage divider resistor to suit. I know that this basically means that when only one device is hot the fan will run based on the average of the two temperatures and not the maximum, but i was sure that in a laptop with a single fan the temps will average themselves out, and they do. Upon inspecting the thing i noticed that the fan was 3-wire, so it was voltage controlled not PWM. I had to do some extra hax to the board, namely adding a MOSFET and lowering the PWM frequency from 25kHz to somewhere around 10Hz, didn't measure it exactly. Anyway, the PWM clicking is barely audible and that only if you put your ear close to the exhaust, and once the fan ramps up you can't hear it at all.
            Result: Success. With everything maxed out, the CPU runs in the high 80s, and the GPU just a smidge over 90. That's still high, but at least it doesn't turn off anymore and can be used to its full potential. In games the temperatures are going to be lower. So, the fan can do it, they just didn't bother to configure it properly...
            Another nice touch, that i realized only after we put the thing back together: I wired the power to the controller to the USB 5v supply, which means that even after the laptop is turned off, the fan will continue to run until the heatsink has cooled. It does not do this on battery, as the USB power is cut to avoid a forgotten peripheral from draining the battery.
            Here some pics. Before you ask: Yes i did move the wires away to clear that screw hole before i put the board back in.
            • lord
              • May 2011
              • 319
              • Croatia
              Re: Fan-Hax Inc
              Nice job!
              I am amazed
              • c_hegge
                • Sep 2009
                • 5219
                Re: Fan-Hax Inc
                Niiiiice. The original overheating problem sounds typical of Acer.
                EDIT: I might have to do a similar thing to a Toshiba Satellite A200 I just scored.
                • mariushm
                  • May 2011
                  • 3799
                  Re: Fan-Hax Inc
                  Are you sure it will not start smelling like burnt cables once that heatpipe goes hot?
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    • Romania
                    Re: Fan-Hax Inc
                    Yes, i am sure. I got asked about that before i wrapped the whole thing up. All wires are covered with kapton tape, they don't touch the heatpipe. If you were asking about the wires on the sensor on top of the CPU, i added a bit more tape after i took the pictures.
                    • lti
                      • May 2011
                      • 2558
                      Re: Fan-Hax Inc
                      I don't think it is Acer's fault. That looks like a Compal board. Acer probably used a standard Compal barebones system without making any changes to its design. HP and Toshiba do the same thing.
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        • Romania
                        Re: Fan-Hax Inc
                        It said HannStar on it... i believe Quanta designed the board it as that's their usual factory.
                        • lti
                          • May 2011
                          • 2558
                          Re: Fan-Hax Inc
                          It could be a Quanta board. I can't tell who made a certain laptop.
                          I wonder who makes all of those laptops that look identical aside from the color of the plastic. My Toshiba is one of those "clone" laptops. They might be made by Quanta and Compal might make the good laptops.
                          My old HP laptop could have used a fan controller like that, but it wasn't worth it for such a slow computer. I tried putting a fan controller in my desktop computer, but the fan runs at the same speed constantly.
                          • c_hegge
                            • Sep 2009
                            • 5219
                            Re: Fan-Hax Inc
                            I couldn't be bothered fan-haxing my A200, so I just wired the fan straight to 5V on the SATA connector. It's not actually all that loud even at maximum speed. I'm posting from it now.
                              • Jul 2011
                              • 6070
                              Re: Fan-Hax Inc
                              Do you have a updated board made
                              Also do you have the board file that you used could you post them and where you had the board made
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                • Romania
                                Re: Fan-Hax Inc
                                Unfortunately all the files are currently offline because my HP DV9000 died for good, but will get them off the drive sometime these days. I made the boards myself.
                                • CapLeaker
                                  AcuRite 5 in 1 temperature sensor replacement repair
                                  by CapLeaker
                                  Got a new victim:
                                  AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
                                  A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold!
                                  B: stuck at some temperature and maybe updating once in 12 hrs or so.
                                  Easy solution is to go to AcuRite website and purchase the sensor. Right?...
                                  04-15-2025, 01:32 PM
                                • asdas09
                                  Temperature to remove chips from motherboard
                                  by asdas09
                                  What temperature with the heat gun should be use to remove large and small chips from the laptop and mobilephones motherboard? My problem is that the chips not easily remove from the motherboard, example 380°C degrees. I don't know if there is a difference with the devices that the temperature is not stable with them even it shows the right temperature, what should it be? I don't know if I should use higher temperature but the risk of destroying other components?
                                  I have device Sugon 202. I'm used also normal flux and rosin flux.
                                  09-12-2023, 12:44 AM
                                • Dreigas
                                  ISL95880HRTZ desoldering temperature
                                  by Dreigas
                                  I bought from China ISL95880HRTZ (3+1+1 Voltage Regulator with Expanded ICCMAX Register Range Supporting IMVP8 CFL/CNL CPUs) chip, which I think is not the original one, but anyway, I tried to resoldering it with a 380C hot air station. Seems soldering is pretty good, but the laptop doesn't work (it worked before, but still had some problems with power delivery).
                                  Is there any big chance, that they sent me two fake ISL95880HRTZ chips or did I just use too big temperature for desoldering? I will try with another chip, but I can't find any info about the maximum desoldering...
                                  09-13-2024, 10:59 PM
                                • jm1234
                                  9V relay temperature 40C
                                  by jm1234
                                  Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                                  I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                                  05-09-2024, 03:03 AM
                                • Windows8RTMUser
                                  Repair knowledge for -55c CPU temperature on AMD Ryzen CPUs in bios, the AMD Sideband temperature sensor interface (SB-TSI)
                                  by Windows8RTMUser
                                  Recently I came across an x570 Aorus Elite where the temperature in bios was reporting -55c, i had checked the CPU_TEMP line connected to the IT8688
                                  In my particular case, the SIC line going to the X570 chipset (PM_SIC) was shorted to ground, so far disconnecting the 0 ohm resistors connecting APU_SID and APU_SIC to the chipset has fixed my -55c issue, it seems like -55c is the fallback reading for CPU_TEMP which is just pulled up to VREF on most gigabyte motherboards
                                  I wanted to post this as even the ever-reliable vlab forum was stumped on this issue
                                  tags:...
                                  07-28-2025, 07:26 PM
