Hi I did a reflow on an HP laptop a while back- it was a DV6000 series. The original problem was the internet stopped working- turns out the south bridge chipset was causing the issue (its a very common issue I found out after searching online). Some people said they did a reflow on the south bridge chipset and that fixed it, but lots of people warned that it will not last. They said the only true solution was to reball with lead solder. So I gave the reflow a try- it worked but they were right it only lasted about a month.
So I recently had a customer bring me a mac book pro (2008 model) and the problem was soon as you hit the power button it would turn on and then go right off after 2 seconds. I took the machine apart and saw that the vents were fully clogged with dust. It obviously overheated. I purchased a replacment board on ebay and they said it was a factory refurb board. So I got it and I could tell it was not a factory refurb, I called the guy and he told me it was pulled from a working unit and he reflowed it himself, he said he does it with all the boards he sells, and then sends them to Coremac (a mac repair center) for inspection and they give him a pass certificut. So that gave me an idea- I tried to reflow the chips on the broken board myself. I reflowed the following three chips: 1. GPU,2. CPU, and 3. Northbridge chipsets. I put the board back in after the reflow, and the mac book pro laptop powers up!
My question is will this problem come up again on the mac book pro in a month or so, like the wifi problem came back on the HP laptop? If the problem is likley to return, wouldnt the guy who reflows them all be doing more harm then good? Or was that issue of it only being a short term fix apply to just the south bridge chipset on the HP laptop?
