MSI GT70 2PE Voltage dropping on the main power rail
  • HERETIK10
    • Dec 2020
    • 15
    • France
    I have a strange problem (for me) on an MSI GT70 2PE laptop.
    When it's under heavy load, power goes steadily to the battery (for 2 or 3 seconds) then return to the charger. If I remove the battery it turns off.
    The higher the load, the lower the voltage on the main rail. We go from 19.5V, PC connected to the charger but turned off (normal consumption of 0.06A)
    On, when it draws 2A the voltage is 19.2V, then eventually collapses to 18.5V (and turns off) around 5A.
    I removed the first 2 mosfets (PQ13 & 14) from the main rail, without noticeable change.
    Anyone have a lead?
    Thank you in advance for your help.
    Schematic : https://www.badcaps.net/forum/troubl...631-schematics
  • mon2
    • 14988
    Is the power adapter properly rated for this laptop use?
    • HERETIK10
      • Dec 2020
      • 15
      • France
      Thank you for your answer. Yes no problem at this level, I had the problem with my original charger and my 60V 12A lab power supply.
      • mon2
        • 14988
        Review the voltage to ground on PU11 (charger IC). There should be a resistor based voltage divider that will accept the main DCin adapter voltage and lower it to a safe value that is being monitored by this charger IC. If the threshold of the lower voltage is within range - the ACOK signal should be true. If the voltage drops below this threshold, the ac adapter is not suitable. Review the conditions when the voltage of the main power rail drops. Suspecting that the threshold of 2v7 (typical) is no longer valid. Review the charger IC datasheet on how the ACDET pin functions.
        • HERETIK10
          • Dec 2020
          • 15
          • France
          Thanks for your response, but I don't think it's a charger problem. Indeed, once the voltage drops too low, the PC goes on battery, it looks like I have something shorted on the main rail which creates resistance. But I don't see what it could be... I soldered a wire directly to the output of PQ14 from my lab power supply and the problem remains the same. The voltage drop begins at low consumption (1A) and intensifies as a load is applied.
          • HERETIK10
            • Dec 2020
            • 15
            • France
            Is it possible that a failing CPU mosfet could create this type of problem?
            • mkdj
              Acer TravelMate P214 - N19Q7 main power rail shorted to ground
              by mkdj
              Dear all,
              I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
              I have checked resistance across each of the 4 MOSFETS. I have the following readings:
              Both N-Channel Mosfets: nothing odd
              P-Channel MOSFET number 1:
              source - drain : 117 kOhm
              source - gate: 96 Ohm
              gate - drain: 117 kOhm
              P-Channel MOSFET...
              08-20-2025, 06:08 AM
            • SarcasticOP
              General question about MacBook power rails for repair.
              by SarcasticOP
              I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
              • PPBUS_G3H (12.6V-12.8V)
                • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
              • PP3V42_G3H (3.42V)
                • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
              • PPVRTC_G3H (3.3V)
                • This
              12-12-2024, 05:50 PM
            • Nagy Daniel
              Lowest possible resistance on laptop motherboard rail - Guide Table request
              by Nagy Daniel
              Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
              I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
              I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
              So, I generated a table with AI so I can...
              03-04-2025, 08:24 AM
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • ROONEY50
              Voltage Injection on 3.3v rail
              by ROONEY50
              I am repairing a laptop that has a short on it's 3.3v rail. I injected 1v on the rail and it was pulling 200mv but can't find any heat anywhere with thermal camera or alcohol. What else can I do to find what's shorted?
              10-11-2025, 12:37 PM
