Laptop Asus Strix G15 power up, but always black screen
    Hi im Monster ("nickname"), i will explain what happens with this laptop pc:
    Asus Rog Strix G15 : model = G512LW
    The screen is not broken, almost not physically.
    When i power up the computer this run perfect but nothing show in screen, also in HDMI port.
    More or less 10 sec later, when win 11 is loaded , HDMI show things i mean user login in win 11.
    Original or main screen doesn't works, anytime, but HDMI works fine when win11 load nicely.
    When win11 is loaded , i check device administrator, and i found a system firmware error, so what i need to do to fix that, i need flash bios? what means system firmware marked as error, .
    Is that the problem.
    I cant go to bios menu , its like no exist bios, because f10 and enter will shutdown if u are inside bios menu, but never shut down.
    The problem that,and what i need to solve is:
    What i need to do for solve firmware problem.
    If the probles is the bios i need a version for ch341 because oficial bios doesnt work with ch341, almost i know.รง
    If some one have similar problem or have bios i will very ty for you help .
    I alreay tryied to installing with myasus, but im sure that will no work.
      Try the EZ update tool:
      https://www.asus.com/support/FAQ/1012152/
        I cant go inside Bios , black screen i can not see anything, the pc doenst go inside bios menu if i press f2
        Let me explain when i pres f2 win11 doesnt wake up, so i use f10 to save and exit to load again win 11, but f10 and enter, doesn't work.
        So win11 don't turn on again until y restat manually, presing power button 1 time to shutdown and again to start up.
          Im trying to do the modify bios from Ez utillity tool, but im stuck at the chose CSME version
            Laptop asus strig g15
            Model: g512lw
            S/N: L5NRKD002295208
            Y posted my bios, i tryid to do it my self but i cnat do it, i dont have any programs for make a new bios using my old bios. Also i dont know check a bios file and if this is correct.
            Hi. Please post this request in the dedicated bios forum.
