820-00138-A got image but no backlight
  • Salem Aboshala
    • Jun 2024
    • 8
    • LIB
    Dears, this is my first post here and first try to fix my own laptop Apple MacBook Pro Retina 15-inch Mid 2015.
    I have some general electronics troubleshooting experience and still as my hoppy but this is my first laptop trying to fix.
    History: my laptop backlight stopped working without any reason.
    Symptoms:
    I have image on screen using my flashlight.
    I have fully working laptop with the help of my external SAMSUNG LED tv via HDMI cable.
    Keyboard backlight still working and can be adjusted normally.
    Since two days I tried to follow all similar issues here this forum and still in the same place.
    Tried to test with another "used" 820-00138 logicboard brought from ebay but still no backlight. Could be the same issue (faulty U7701)??
    From first visual inspection there is no any sign of liquid damage nor corrosion nor any sign of component failure.
    I followed the schematics carefully and there was nothing wrong with all measurements in LCD Backlight driver circuit.
    Here are the volt readings as I still remember on U7701 :
    1,2=0v
    21=0v
    5,18=5v
    9,10,11=12v
    17=3.3v
    PPVOUT_S0_LCDBKLT=0v
    PPBUS_S0_LCDBKLT_PWR_SW=0v
    PPBUS_S0_LCDBKLT_FUSED=12v
    PBUS_SW_LCDBKLT_PWR=12v
    I followed all measurements on LVDS connector (J8300) and was fine I guess except this pin #8 (LCD_BKLT_PWM_R) which I think not normal:
    When I power on the laptop there is another chip pulls down this pin to 52Ohms, but it is open circuit in power off mode. I checked with / without LVDS cable and the same behavior.
    From my own primitive experience, I think (U7701) still needs some information from another chip (i2c I guess) to start boosting.
    FYI, main LCD is normally detected by OS and tried SMC and PRMA reset but nothing changed.
    Could anybody help in this case ?
  • mon2
    • 14677
    1) Welcome.
    2)
    Never power the board and measure in resistance or DIODE mode with your meter. Always remove all power before using either resistance or diode mode of testing.
    3) With power to the board, meter in DC volts mode (10 volt or higher scale is ok) - measure the voltage to ground of:
    I2C_BKLT_SCL ; as below
    I2C_BKLT_SDA ; used to configure the internal registers of the backlight controller
    EDP_IG_BKL_ON ; this is the enable signal for the backlight
    Post each measurement.
    Adding to your workload:
    4) Remove all power. Meter in resistance mode (not diode mode). Measure the resistance to ground of PPVOUT_S0_LCDBKLT. We are wanting to check the resistance to confirm if there is a shorted component on this boosted power rail. It is possible that the backlight IC attempted to boost the voltage but due to a shorted component, there was an excessive current draw and then the charger IC turned off the backlight.
    5) The P-channel mosfet @ Q7706 will enable if the gate pin # 3 is negative or lower than the voltage being passed through source & drain pins. That is, if R7702 is pulled to ground through the charger pin # 11 then a voltage divider will be built for pin # 3. Then R7702 & R7701 will work to lower the voltage that is incoming @ PPBUS_SW_LCDBKLT_PWR and this new lower voltage is enough to enable the Q7706 mosfet to pass the voltage onto the LCD backlight circuit. However, the backlight IC must pulse the use of this voltage on / off to boost to a voltage of 25-45 volts to light up the LED array that resides inside the LCD display. It is possible that the backlight IC is defective but perform some tests and post your results.​
    • Salem Aboshala
      • Jun 2024
      • 8
      • LIB
      1. Thanks alot for your reply and greetings mon2
      2. My little multimeter from Uni-T and it has auto-mode feature and it starts with sensing ac/dc voltages first, and then it starts to look for resistance if there was no voltage detected (UT123D).
      3. 4.78v , 5.03v and EDP_IG_BKL_ON​=3.33v coming via R7742 (0Ohms)
      4. It gives 14Kohms and then goes to 500Kohms repeatedly, I even injected external power (50v) to insure no leakage and there was 0mamps.
      5. Q7706: 12.66v@pin#3 , 12.76v@pin#4.
      I think Q7706 will stay off till BKLT_SD goes down right ?
      Thanks alot for your contribution
      Appreciated
      • Salem Aboshala
        • Jun 2024
        • 8
        • LIB
        Correction, I2C_BKLT_SCL = I2C_BKLT_SDA​ = 5.03v now, or maybe it is different slightly from time to time as it is a communication signals right ?
        • mon2
          • 14677
          Yes on Q7706.
          The measurements look good and the backlight is being enabled.
          Remove all power and confirm diode D7701 is ok. Test in diode mode. With no display attached, the diode should conduct in one direction (not the band) and block in the other.
          Your smbus / i2c lines look ok and not stuck.
          Update: If you wish to try, take a piece of wire and mate one side to ground (shield is ok) and the other side to pin # 3 (gate pin) of the mosfet @ Q7706. This will force the Q7706 mosfet to enable. If indeed, the backlight IC is being enabled and ok, it should be able to boost this 12v input voltage.
          Assuming that the LED return signals are connecting to this backlight IC OK + D7701 is ok + Q7701 is ok -> the voltage should be boosted.
          • Salem Aboshala
            • Jun 2024
            • 8
            • LIB
            Thanks alot agin mon2 for your follow-ups,
            Already checked = OK
            I think you meant to short BKLT_SD to ground, but I shorted pin#4 & pin#6 instead to bypass 12v to PPBUS_SW_BKL, and I got what I expected at PPVOUT_S0_LCDBKLT = 12v, which means the booster still wont work.
            I think U7701 still get LCD not ready for LED power on, otherwise pin#11 (BKLT_SD) should start signaling right?
            • Salem Aboshala
              • Jun 2024
              • 8
              • LIB
              I did tested the following:
              1. Connected external 48v LED strip the PPVOUT_S0_LCDBKLT line and the booster didnt work.
              2. Injected LED tester @ PPVOUT_S0_LCDBKLT with 10mAmp and there was no current drawn from Retina LED.
              Here I started to think the Retina display has a defective LED circuit and asked U7701 not to start boosting.
              Is there anyway to test the Retina LED from external source ?
              Any thoughts would be appreciated
              • Salem Aboshala
                • Jun 2024
                • 8
                • LIB
                Good news, I started to disassemble the LCD and I discovered one cable disconnected (CNT201), just reconnected it and the backlight is working fine now.
                So many thanks mon2 for your help
                Have a great day
                • zaurus81
                  Yashi All in one model AY62409 (Quantum S 24'') no image (backlight works)
                  by zaurus81
                  This chinese all in one computer gives an image when connected to an external vga monitor but only the backlight with integrated monitor (no image). Initially I thought it was an edid problem on the eeprom of the screen but then I saw that the monitor works correctly with another identical motherboard (model th410-d4, read by bios). Unfortunately the motherboard is chinese and has no brand or codes on the pcb. The format seems ITX. Nothing can be found online. The official yashi site provides drivers but not the bios. The electrical diagram is obviously unobtainable
                  The board is equipped...
                  01-16-2025, 03:54 AM
                • Constantinos
                  Macbook Pro A2442 820-02098 No image but has backlight
                  by Constantinos
                  Hi all
                  I have a Macbook Pro A2442 with the 820-02098 from a friend which has no picture on the display, however, the backlight works.
                  He was streaming a football match on a questionable site, then the site crashed, and the problem emerged.
                  Initially, he sent it to apple, who quoted him £1323.95 to replace the display, lid angle sensor and top case.
                  Obviously, he decided against this and gave it to me so that I could have a crack at it.
                  From initial diagnostics, I connected to an external monitor, I first tried with a HP 22W monitor, and I booted into the boot menu...
                  08-24-2024, 09:48 AM
                • ajgae
                  HP Pavillon x360 14-ba174nz no image no backlight, LCD_VCC low (2.25V)
                  by ajgae
                  Hi everyone!
                  First post on here so do tell me if i'm doing anything wrong. I have a laptop that came in with a broken hinge, but a healthy LCD. We replaced the LCD rear cover and now we do not get an image on the LCD anymore, though we get one via HDMI. There is sadly no schematic or boardview available for this motherboard (Bucks U42 DIS 17817-1) as far as i can tell, but I was able to identify which of the important pins on the LCD eDP connector (30 pin 2 lane) correspond to which pins on the motherboard display connector (which is 40pin, 30 for LCD and 10 for camera/face rec etc)...
                  03-06-2025, 09:53 AM
                • learnmore
                  Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
                  by learnmore
                  Hello Community!
                  CASE DETAILS
                  Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
                  13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
                  Tried inserting firmware on USB and left it in for a few hours, but no change
                  03-03-2024, 09:49 AM
                • dfear
                  ASUS Vivobook X1500e - no image and no backlight. Can this be fixed?
                  by dfear
                  ASUS Vivobook X1500e came in with no image and no backlight.
                  Motherboard is: x415ea.
                  Current knowledge/observations:
                  RAM, LCD & LID sensor = oood.
                  LCD connector - AC_BAT_SYS_ is present.
                  D4501 schottky diode - LCD_BACKOFF# is always 3.3V, whether the lid is closed or not.
                  CPU thermal signature seems normal.
                  Laptop boots and outputs to HDMI.
                  Is part of the CPU bad or can this be fixed?
                  10-14-2025, 04:02 AM
