please help friends thinkpad T470 error post "bottom cover tamper detection error"
  • fredyjbi
    • Feb 2021
    • 144
    • malaysia
    please help friends thinkpad T470 board CT470 series NM-A931 error post "bottom cover tamper detection error"
    I've already
    flashed the bios clean me and updated from the Lenovo site, then removed the switch and immediately jumped the S3 from pins 1 to 4, 2 to 3 but the problem remained the same, thank you
  • mon2
    • Dec 2019
    • 14116
    INTRUDER# netname has a '#' as a suffix. In the digital logic world, the hash-tag suffix denotes that the signal is active LOW. That is, if this line is ~0v = logic low, then the signal is active. So if 0v, INTRUDER alert.
    Respectively, remove the short applied between S3 pins 2-3. This will remove the hard short to ground and then the pull-up resistor (R646) on the same signal will be parked to the logic '1' state. Test again.
    • fredyjbi
      • Feb 2021
      • 144
      • malaysia
      Sorry sir, I am late in giving an answer, sir, I have removed the pin 2 to 3 jumper, and also replaced the R646 resistor but the results are still the same, thank you and where should I check again
      sw3
      pin1 3.3v -INTRUDER_PCH
      pin2 3.3v
      pin3 3.3v
      pin4 0v
      D5
      pin 1 3.3v
      pin2 3.3v -INTRUDER_EC
      • mon2
        • Dec 2019
        • 14116
        The logic levels look correct to me since the parked state is a logic '1'.
        Review the BIOS settings under SECURITY to see if this setting can be disabled.
        Some Lenovo ThinkPad notebook systems contain a mechanical tamper detection switch - Lenovo Support US
        • fredyjbi
          • Feb 2021
          • 144
          • malaysia
          thank you sir for your help, yes this case is very strange sir still the tamper error, I have checked the bios security position is disabled, thank you Click image for larger version
          • charliee
            • Aug 2023
            • cn
            I think the EC chip (Embedded Controller,MEC1653) may have a soldering defect.
            Place the motherboard steadily,and try heating the EC chip with a heat gun to 230°C for 1 minute.Then let it cool down naturally.
            Or you can also consider replacing the chip.Note that this chip has a built-in program. Please make sure that the spare part​ also has a program.
            • charliee
              • Aug 2023
              • cn
              Or you can also consider replacing the chip.Note that this chip has a built-in program. Please make sure that the spare part also has a program.
              [UPDATE]
              You may need to check whether these components are normal first. If they are damaged, this error will also occur.
ID:	3342544Click image for larger version
              • bhatt
                • Dec 2015
                • 93
                • pakistan
                I've already
                jumper 1+2 2 and 3 and 4
                  Lenovo ThinkPad T470 Notebook T Specification for Upgrade or Repair
                  This specification for the Lenovo ThinkPad T470 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T470 boardview and T470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                  09-06-2024, 03:30 PM
                  09-06-2024, 11:40 AM
                  09-06-2024, 11:29 AM
                  09-06-2024, 08:52 AM
