Asus EB1501 power on failed
    Since 2 weeks, my eeebox 1501 won't start. First, i thought bios bug or something like this. I found this helpful site which explain how to fix reboot issue with a clear CMOS :
    http://kloakens.blogspot.fr/2012/04/...own-issue.html
    Unfortunately, for me, it doesn't work
    To check power switch, i measure the voltage on the switch himself . I see 5v before to press button and the voltage falls to zero after release the button. I don't have schematic, but i think the voltage should be return to 5v after release the button. The button should works like a reset circuit.
    May be shortcut on power, like a bad capacitor ? I don't know ? All capacitors looks like corrrect (all are flat). Is it helpful to change them ?
    Do you ever seen something like this on Asus eeebox ?
    Thanks in advance,
    Regards
    Stéphane
    Re: Asus EB1501 power on failed
    Tried reseating the Ram? Perhaps post good clear pictures of the back and front of the board - maybe someone will spot something.
      Have you tried another power adapter, these seem to be the weakest link...
        Check EC, flash bios.
          Thanks for your answers !
          Selldor, I have already reseated the RAM but nothing had changed. Yes, i will post pictures ! Good idea but I have to find my camera
          khaahk , may be power adaptor, yes. It 's seems ok to the voltmeter but i will change it to loboratory power supply. This will allow me to limit and measure the current. how many of ampere this small machine could consume in normal time ?
          Spidey, how i can check EC flash bios ? i saw SPI pin connector just behind the EC bios.
          May be i can use it to read the bios. Not so easy i think !
          So, tommorow i will find camera and laboratory power supply
          Thank you very much and have a good day
          Regards
          Stephane
            Should be a good clue on the power adapter label?
              I plugged my EeeBox on my laboratory power supply. The current consumption is only 0.05 A (about 1W) ! Maximum current labeled on the power adapor is 3,42 A ( so 65W with 19v) and i limited the current on my power supply at 0.5A to be sure do not destroy components. But, as soon as I press the ON button, the power supply indicates 0A.
              If I had a permanent short circuit with one of the components, I should have a bigger current. So I assume that the system goes into safety mode and disconnect the power circuits.
              Or the bios is corrupted as indicated by spidey and I'll have to play with spi !
              But it seems possible :
              http://bios-repair.co.uk/SPI-ISP/spiflash.html
              I posted pictures, If someone sees something suspicious do not hesitate to tell me!
              Regards,
              Stéphane
                Hmm
                Soldered cpu.. Where could be the problem.
                Reflow cpu and cipset
                  first check voltage to this 8 pin, then if both side of each one is shorted:
                    Hello dellxps15,
                    2 resistors are supplied. One of them delivers 5.29 V and the other 3.13V. The 5.29V voltage is the same I found on USB. These voltages are issued by Mosfet "k0355" controlled PWM I think (I would have checked with oscilloscope).
                    And then when I press ON I lose all voltages except the 19v applied to the mosfets. I do not think the mosfet are damaged because when I have no output voltage, the Gate is no longer supplied.
                    Regards,
                    Stéphane
                      Originally posted by dj_ricoh View Post
                      Hmm
                      Hello dj_ricoh,
                      Maybe but I keep this method as last chance ! It's a bit complicated for me
                      Regards
                      Stéphane
                        I think what dellxps15 was trying to say is, check if the coils are short to ground.
                          Ho, sorry, I thought it was resistors! In ohmmeter, one of them (the lower) shows only 3.5 ohm connected to the ground. It's low! While all of them are behind a mosfet in series with the supply line! I will investigate that !
