HP14 - DA0G7GMB8F0 REV.F
    Will do but can you show me where Source & Drain are on this chip as it has 2 gates and 3 pins one side and 3 on the other. Thanks.
      Sure - see attached. Get a bearing of pin # 1 and locate the belly pads that will be visible on the North and South of the body as shown in the datasheet here:
      Pin # 1 = DOT / DIMPLE = Top Left of the mosfet and the first pin is the G1 pin. Then count in a 'U' counterclockwise direction for the rest of the pins.
      Click image for larger version  Name:	mosfet_pinout.png Views:	0 Size:	248.7 KB ID:	3303989
        OK thanks for that. 😀
        Source to Drain - 43K ohms
        Source to Gate 1 - 78K ohms
        Source to Gate 2 - 2.4M ohms
        Gate 1 to Drain - 1.34M ohms
        Gate 2 to Drain - 4.7M ohms.
          Just found another MOSFET below the one I just measured (with a coil between it) and its exactly the same QA3112
          Source to Drain - 1.2M ohms
          Source to Gate 1 - 1.5M ohms
          Gate 1 to Drain - 180K ohms
          Gate 2 to Drain - 3.6M ohms.
            The measurements with kohms are of concern. I would consider to source some spares and replace these parts. You can also flux each (make a note of their location #1 position first); remove off the board and then test each when the parts are on your work bench. Confirm is the measurements remain this low.
              I took the mosfet off and the readings are reading OL
                I think I might change the MOSFET anyway. I have some old boards but none of them have a QA3112 on them but I found a board with 22CF FDMS3660S MOSFETs which looks similar. Could you compare them and let me know if they would be suitable? Many thanks.
                  Anyone?
                    The replacement looks suitable - not as high current drain support as the original but is worthy of testing. Same pinout, etc.
                      Many thanks will give it a go.
                        Well I changed the MOSFET and the laptop is still doing exactly the same!! On and off every 3 seconds. So frustrating.
                        Is there anything else I can try? I'm determined to get this going.
                          Do you ever see any text / graphics on the display during the 3 seconds the power is on? You may have a dead CPU.
                          Remove all power / no battery. Meter in resistance mode (not diode mode). Measure the resistance to ground of each inductor. Checking for a low resistance measurement. Post any suspects.
                            No text and no backlight.
                            7 inductors on the board.
                            1 - 0.5K ohms
                            2- 1.10K ohms
                            3 - 37K ohms
                            4 - 0.8K ohms
                            5 - 0.7K ohms
                            6 - 0.7K ohms
                            7 - 36K ohms
                              Board with the inductors numbered.
                                Seems a bit low to me but then I don't really know anything about this.
                                  Can anyone help?
