a2338 2020 Macbook Pro liquid damaged won't turn on- weird issue
  • bigbadbios
    • May 2021
    • 8
    I am trying to fix this liquid damaged 2020 Macbook pro and I noticed something weird.
    When I push on/around the renesas 501cr0b IC, which appears to be a clock generator/ multiplier, If I apply lot of pressure, the device will reach 19.9 volts and seems to be trying to work.
    I have thoroughly reflowed that area and completely removed that chip (there was some liquid stain in that area) but no help. I have just 5v 0a unless I apply the pressure.
    Your help is GREATLY appreciated. Thanks!
  • mon2
    • 14663
    Best for you to post some clear pics of the reworked part. In general, flux the part well and enough heat and low air pressure to melt the solder and allow the pcb pads to meet the device pads like melted butter.
    • bigbadbios
      • May 2021
      • 8
      Click image for larger version  Name:	IMG_0498[1].jpg Views:	0 Size:	1.48 MB ID:	3332719
      Thank you for your response.
      It is U5700 on the schematic, the board is 820-02020-a.
      I have went as far as to remove the chip entirely and reseat with a river of flux, still no go. Also reflowed the areas around it on that side and directly under on the opposite.
      • BMCappelletti
        Macbook Air A1466 EMC 3178 missing power and liquid damaged
        by BMCappelletti
        Hi everyone.
        Macbook Air A1466 EMC 3178 (board 820-00165 A) not turning on and no charging light. Completely dead. With no battery connected it would power up and I could hear the chime, but nothing on the screen and then a sudden turn off. Sometimes during the chime. Opened it up and found some liquid damage. The flat that connects both boards has damage in one side (with a missing pin already). The connectors on the boards are fine, though.
        Also, there was liquid damage on the included picture area, which are R8111 and C8111. A quick and soft brush on it made the resistor be gone....
        04-15-2024, 01:24 PM
      • redbaron1007
        Liquid damaged macbook A1466 fan spins, but doesn't turn on.
        by redbaron1007
        I got a tricky one today in the form of a macbook air A1466 820-00165-A that will recognize the charger and turn the light green then back to orange and the fan will spin constantly, but the system won't power on. The screen never turns on, it doesn't make the bong noise it's supposed to, and pressing the power button doesn't do anything. When I took the board out to visibly inspect it I only found one spot of corrosion on the bios IC. I pulled the chip, cleaned it and the area with IPA and put fresh solder on both and put the bios chip back on, but when I went to test it again it still does the...
        10-24-2024, 05:45 PM
      • dbuergi
        MacBook Pro A2338 liquid damage repair for a beginner?
        by dbuergi
        i have a A2338 with water damage on the logic board. Cleaning it showed some heavier corrosion around U7000 and surrounding caps. Some are totally broke.
        I get 5,2v when using both USB-C Ports but until now i didn't make any more tests.
        Since i'm a beginner i want to know next possible steps. I'm not afraid replacing the intersil 9240hi but the other parts with 1mm or 2mm scare me and i don't know where to get replacements.
        I fixed other laptops but this ist my first apple device ....
        07-24-2024, 09:48 AM
      • fajfelek
        Macbook Pro M1 a2338 after liquid damage - Need help with identify missing part on trackpad logic board
        by fajfelek
        Hello, First of all thanks you for reading this topic.
        I need your help with identify missing parts on trackpad logic board (661-18430).
        The liquid got into the orange area, but I found that the green area had some parts missing or burnt.
        Please help me with identity parts from blue and red area .
        06-15-2024, 01:41 PM
      • jkruns
        M1 A2338 screen and touchbar issues after cleaning up liquid damage
        by jkruns
        This is my first post after browsing this wonderful treasure trove of knowledge for many, many evenings. I've decided to learn how to fix these things, properly.
        My patient is an A2338 Macbook Pro M1 (late 2020).
        It had some corrosion around JT710 and JT700 caused by liquid spill, as well as against the protective barrier around the USB-C chips UF000 and UF100. So I took the main board out and cleaned it with a toothbrush and alcohol, then with alcohol in an ultrasonic cleaner. Cleaned the touchbar flex connectors as well. The board looks...
        04-22-2024, 06:45 AM
