Help in identifying a component - HP 15-cs3009na DAG7BLMB8D0
  • Rickkap
    • Aug 2015
    • 130
    A shop changed the fan on the above and it stopped booting so they sent it to me. All I get is 5 long 3 short flashes on the CAPS lock. I tried flashing the bios and EC chip still the same and then i noticed 3 components missing (2 x resistors and a capacitor) from near to the fan connector.
    I've checked and there is not schematics available for this model, so I need help in finding out what the values are of the 2 resistors are, I'm not that bothered about the capacitor. I know that's going to be very difficult unless someone has a donor/working motherboard so i thought i would try and work it out from the main chip which the are connected to.
    The marking on the main chip is 5V=7K and under this is L97
    Any help would be much appreciated
    Click image for larger version  Name:	chip1.png Views:	0 Size:	673.0 KB ID:	3529095 Click image for larger version  Name:	chip2.png Views:	0 Size:	1.55 MB ID:	3529096
  • mon2
    • 14190
    Richtek RT3612EBGQW
    Datasheet:
    https://www.google.com/search?sca_es...&bih=915&dpr=1
    https://www.aliexpress.com/w/wholesa....home.search.0
    • Rickkap
      • Aug 2015
      • 130
      Mon2 thank you so much. So i've had a look at the datasheet and the resistors that are missing are from pin 4,5 VDIO, VCLK to the CPU.
      Still not sure what the values of them would be.
      Anyone would like to have a guess or do i just put 0hms in there.
ID:	3529122 Click image for larger version
ID:	3529123 Click image for larger version
      • R_J
        • Jun 2012
        • 9535
        Here is a schematic for an Acer aspire that also uses that RT3612EBGQW ic Page 88
        • Rickkap
          • Aug 2015
          • 130
          Thank you... Looks like i need a 45.3_0402_1% and 100_0402_1%
          Where the hell am i going find a 45.3!!!!
          Thanks again both of you for your help... time to raid the donor boxes and get probing
          • mon2
            • 14190
            https://www.digikey.com/en/products/...KF45R3X/192366
            https://www.digikey.com/en/products/...07100RL/726527
            • Rickkap
              • Aug 2015
              • 130
              Thanks Mon2
              I found them both on a Dell donor board... both swopped and we have a working HP laptop again.
