Like title says A2141 came in with Water Damage, customer desperately wants the data.
The actual water ingress doesn't appear too bad it sat for a day but was very dusty internally. I have no idea why L8504 was arced there is no apparent moisture there or around the LVDS cable; however, the LVDS to screen screw studs had popped off at some point and somebody tried securing it with kapton tape.
I had to create a micron wire pad jumper to reconnect the south side of the L8504 since the primary pad was blasted down to the vias.
That said after cleaning up the board only the right side USB would draw 5V and .25 amps, the Left side power cycled.
Inspecting the PCB with the USB power connected to the Right ports shows the only device on the laptop getting warm is the T2 Chip under the black shielding tape.
There doesn't appear to be a short on PP2V5 or PPBUS_G3H.
I swapped U3100/U3200 from an 820-01700 which fails DFU recovery. I am able to get the U3100 Port to behave the same as the right hand ports, the U3200 Port reads 5V 0 amps.
Its possible I didn't get enough solder on all of the pads. I don't have a stencil for the USB control chips so I just tried re applying solder with flux, I noticed some of the pads don't appear to want to take a dome of solder possibly not heating up enough They stay fairly flat compared to the others? I tried putting a layer of solder paste on the cleaned pads, flowing with hot air tool then removing the excess ball that formed with an iron.
Are there any tricks for half assed rebelling of the CD3217?
I am keeping my fingers crossed that this thing isn't in DFU, as always any tips or suggestions greatly appreciated.
