HP G6 Series - Quanta R13 - NO DISPLAY, NO RUN VOLTAGES, VRON Missing...
    Re: HP G6 Series - Quanta R13 - NO DISPLAY, NO RUN VOLTAGES, VRON Missing...
    i got 2xi3 and i5 defective.
    you understand why i ask and btw everyday i upgrade notebooks and its only 30% that it will fit.
    so those cpu are 100% working? if not compatible? cuz if its not then...
      Originally posted by loser18 View Post
      But when checking PU13 for HWPG without CPU voltage jumps up...
      Yes...Exactly...
      What about VR_ON?
      HPWPG has also to do with PU3, PU11, PU4 and PU1.
        100% compatible...
        One is i3-2330M & the other i3-2350M...
        I've got a strong feeling that one of them may be faulty, but both???
          Originally posted by atsio View Post
          What about VR_ON?
          I know...for example PU11 has 2 signals one is 1.05V_VTT_PWRGD which should enable PU1...So complex...
          I don't understand that HWPG signal...
          What's the flow?Does it go from regulator to regulator and last one sends to SIO or all of them???
            All of them. All receive mainon. See timming from similar boards
              OK...UPDATE...
              Now also getting +1.5VSUS but PL16 & PQ9 is getting hot...
              Will replace & post results...
                awesome!
                after this post i will stop destroying g6 motherboards :|
                  awesome!
                  This mobo is like fuckin puzzle game,lol...
                    PU9 replaced...I've checked literally everything around it, but still getting hot...
                    When checked Q36 noticed that on PIN4 (gate) is around 10V...(it's a AON4470)
                    Is it normal???
                    It's also getting hot...Replaced PU2 but still the same...
                      replaced million components...
                      PU9 still getting hot...
                      Got no output from PU11 which is +1.05V PCH power rail,all other voltages are OK...(with CPU)
                      Replaced PU11 & all fets related...
                      Without CPU I've got all voltages (@ coils) before DRON (I mean they jump up for a sec)...
                      Even reflowed U24, but still the same...
                      THIS FUCKIN MOBO DRIVES ME NUTS & WILL BRAKE IT IN A HALF I THINK...
                        Pls, if anybody has this mobo working...Could you post correct resistance @ PL25?
                          Just fucking that shit board
