I got a lenovo g50-80 that shows charging led (orange LED flashing) and when I press the power button the white LED comes on but the laptop doesn't switch on. The fan spins for 2 seconds when I press the power button then it stops. This problem started when my charging dock broke the connecting wires and i soldered these wires back but I might have mixed them. I ended up buying a new charging dock but laptop never switched on it just shows flashing orange LED when charger is connected. Could the super io be bad? I don't know how to go about diagnosing and I can't check any board view since this was my personal laptop that I was using. Please assist with where I should check (if soldering is need then don't worry about microsoldering I can solder and remove chips perfectly)
Lenovo g50-80 charging led flashing but laptop not switching on
Originally posted by mon2 View PostThis is a p-channel mosfet so this is ok. The mosfet is enabled. Next test PQ302. Same measurements.
Then remove all power, measure the resistance to ground of the main power rail (at ACN) of PU301. No power in resistance mode checks.
