ASUS UX363JA No power
  • dclass-pro
    • Dec 2022
    • 157
    • Italy
    Hi guys, I'm repairing a motherboard from an ASUS UX363JA R2.2 that won't turn on, I found a component exploded near the display connector.
    I don't have the diagram so I can't figure out what code it has, also if I power the main with the USB-C I have a draw of about 2A at 5V and it doesn't go to 20V.
    I checked the mosfets and inductors and everything seems ok, but I don't know what to do.
    Do you have any ideas?​
  • noname2024
    • Aug 2024
    • 295
    • CỎ MỸ XỊN
    try Click image for larger version
    • dclass-pro
      • Dec 2022
      • 157
      • Italy
      thanks!!! can you send me the whole brd view and the schematic if available?
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • ShadowAi
        ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
        by ShadowAi
        Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
        Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
        After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
        03-15-2024, 10:46 AM
      • meraklinetx
        Asus Z97-a power cycle, no boot no cpu voltage
        by meraklinetx
        Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
        05-10-2023, 06:08 AM
      • conghuyms
        Request for Help – ASUS G531GW Rev 1.6 – No Power On
        by conghuyms
        I need your support with an ASUS G531GW Rev 1.6 laptop.
        When I plug in the charger, the battery charging LED turns on, but the board does not power on when pressing the power button.
        Here’s what I’ve checked so far:
        • Motherboard has been removed for inspection.
        • 3V and 5V always-on rails are present (3V/5V_ALW).
        • 1.8V and 1.09V at the PCH are present.
        • I don’t have the boardview/schematic, so troubleshooting is limited.
        • I tried checking the power button signal from the
        07-20-2025, 09:14 PM
