Asus K43s Laptop Automatic Power On when charger plugged where to start?
  • bermor
    New Born
    • Oct 2014
    • 6
    • Philippines
    I have asus k43s i3 laptop and when i plugged the charger laptop automatic turn on seems shorted but i don't know where to start my troubleshooting. i suspected a bad capacitor but i doubt if ceramic capacitors are easily get shorted. or if there is a common part of laptop board that get shorted.
    kindly help me and thanks in advance
    Intel Core i5 4th Gen
    MSI Z87-G45 Gaming
    8Gb 1866 Kingston Fury
    2TB[1x2] Storage
    EVGA Nvidia GTX680 Signature 2
    CM Stryker White
  • Ramee
    • Jul 2014
    • 218
    • Israel
    Re: Asus K43s Laptop Automatic Power On when charger plugged where to start?
    Try to replace the rtc batt.
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Are you saying the only fault is that the laptop starts when you plug the adapter in.
      • lorins_core
        BlackSmith
        • Dec 2012
        • 552
        • Philippines
        Can you Check the I/O Chip? example. if Ene or ITE?
        have sometimes Corded or Cold Solder
        • mathog
          • Mar 2010
          • 2655
          Look through the BIOS for "power on" settings. Most computers have one that causes them to boot when power is applied, and it sounds like that is the way yours is set.
          • bermor
            New Born
            • Oct 2014
            • 6
            • Philippines
            I'll reconsider sir
            I'll try also to check the Chip for cold solder
            Thank you i'll update you later,
            MSI Z87-G45 Gaming
            2TB[1x2] Storage
            CM Stryker White
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              I dont like talking to myself - I have an asus laptop that does that - I just let it boot up then power it down. There probably is a setting that will stop it doing that - but its no big deal.
              • tomrush
                • Nov 2014
                • 20
                • Philippines
                exact issue of mine sir, it automatically power on and i don't have any idea where to start. can you help me what to test first sir. i'll appreciate it.
                • selldoor
                  Slow Learner
                  • Dec 2010
                  • 7870
                  Have you tried Ramee's suggestion - replace the rtc (cmos) battery
                  Looks like a problem local to the Philippines together you should be able to sort it .
                  I still dont know if the original poster has only this problem - he mentions something shorted as though the laptop doesnt stay on???
                  Owners manual has this:
                  WARNING! DO NOT connect the AC power cord to an AC outlet prior to connecting the DC plug to the Notebook PC. Doing so may damage the AC-DC adapter.
                  Does it make any difference if you plug into the laptop first then into the mains.
                  It also says you should ONLY use the supplied adapter.
                  In my case I dont have an original adapter and at the moment I dont have any adapter
                  I borrowed one to see if the laptop worked also it is not a K43s it is an old model ASus.
