Macbook Pro 15' 2008/2009
  • magneh
    • Apr 2014
    • 602
    • Portugal
    Hello!
    Got a friend who his getting random shutdowns with his MacPro.
    He has sent me the error he gets :
    Anonymous UUID: 5B5F728D-342F-A385-59DD-A48EA5685BA8
    Wed Nov 26 00:40:15 2014
    panic(cpu 0 caller 0xffffff7f83df9fb0): "GPU Panic: [<None>] 3 3 7f 0 0 0 0 3 : NVRM[0/1:0:0]: Read Error 0x00000100: CFG 0xffffffff 0xffffffff 0xffffffff, BAR0 0xd2000000 0xffffff80a1662000 0x0a5480a2, D0, P3/4\n"@/SourceCache/AppleGraphicsControl/AppleGraphicsControl-3.4.35/src/AppleMuxControl/kext/GPUPanic.cpp:127
    Backtrace (CPU 0), Frame : Return Address
    0xffffff807e683190 : 0xffffff8001a22fa9
    0xffffff807e683210 : 0xffffff7f83df9fb0
    0xffffff807e6832e0 : 0xffffff7f824c0eab
    0xffffff807e6833a0 : 0xffffff7f8258a49a
    0xffffff807e6833e0 : 0xffffff7f8258a50a
    0xffffff807e683450 : 0xffffff7f82809056
    0xffffff807e683580 : 0xffffff7f825adb39
    0xffffff807e6835a0 : 0xffffff7f824c78fd
    0xffffff807e683650 : 0xffffff7f824c5408
    0xffffff807e683850 : 0xffffff7f824c6d57
    0xffffff807e683920 : 0xffffff7f83425e54
    0xffffff807e683a40 : 0xffffff7f834250cd
    0xffffff807e683a70 : 0xffffff7f8341ce19
    0xffffff807e683ac0 : 0xffffff7f83418581
    0xffffff807e683af0 : 0xffffff7f83413378
    0xffffff807e683b20 : 0xffffff7f833fbc84
    0xffffff807e683b70 : 0xffffff8001ecd26a
    0xffffff807e683b90 : 0xffffff8001ecddce
    0xffffff807e683bf0 : 0xffffff8001ecb81f
    0xffffff807e683d40 : 0xffffff8001ab6558
    0xffffff807e683e50 : 0xffffff8001a26bf1
    0xffffff807e683e80 : 0xffffff8001a139f5
    0xffffff807e683ef0 : 0xffffff8001a1e043
    0xffffff807e683f70 : 0xffffff8001ac976d
    0xffffff807e683fb0 : 0xffffff8001af3b46
    Kernel Extensions in backtrace:
    Mac OS version:
    13C64
    Model: MacBookPro6,2, BootROM MBP61.0057.B0F, 2 processors, Intel Core i5, 2.4 GHz, 4 GB, SMC 1.58f17
    Graphics: Intel HD Graphics, Intel HD Graphics, Built-In, 288 MB
    Graphics: NVIDIA GeForce GT 330M, NVIDIA GeForce GT 330M, PCIe, 256 MB
    Gpu error seems straightforward .
    Does anyone got any experience with this BGA chips?
    Needs just reballing or a new BGA?
    Thanks in advance!
  • dellxps15
    • Feb 2014
    • 1596
    • italy
    Re: Macbook Pro 15' 2008/2009
    if datacode is 2009 or newer i think a reball is good.
    edit: there is a way with script to make working only the intel. u can try that and see if u get no more errors.
    hard thing in macbook is taht gpu place is not market in each side, so solder it back in right position is a bit hard.
    • magneh
      • Apr 2014
      • 602
      • Portugal
      Thanks for your input!
      Gonna tell that to the owner and see if he wants to try that script to force only Intel graphics.
      Made a reballing on a MacPro late 2011, no markings and it went well.
      Of course, that doesnt mean it's a garantee, cause it was my first one
      I'll update post if the owner wants to proceed (almost for sure ).
      Cheers!
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        GT330 is known for issues in Macbook Pro due to the very poor cooling of the machine. Reballing should work, but be careful with the temperatures, don't heat it up more than you have to. If the chip has run at very high temps for extended amounts of time it may die during the process.
        A working TV? How boring!
        • piernov
          NVidia bumpgate
          by piernov
          Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
          Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
          May complete this post at a later date with more details.
          Basically issue is a combination of thermal dissipation of the chip with hotspot,...
          03-27-2021, 10:34 AM
        • envym
          by envym
          Hi everyone!
          06-27-2025, 08:54 AM
        • Flasman90
          Macbook Pro DFU Restore Issues
          by Flasman90
          I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
          - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
          - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
          08-30-2025, 10:27 AM
        • tobeend
          Bypass mdm macbook m2 ventura
          by tobeend
          1. RESET MACOS WITH IPSW
          a. Power off MacBook, press and hold the power button to enter Recovery
          b. Open Disk Utility, remove Macintosh HD
          c. Reboot, connect to the network to Activate Mac.
          d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
          d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
          e. Release the other keys, but keep holding the Power key for another 10 seconds
          f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
          05-26-2023, 07:18 AM
        • SarcasticOP
          General question about MacBook power rails for repair.
          by SarcasticOP
          I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
          • PPBUS_G3H (12.6V-12.8V)
            • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
          • PP3V42_G3H (3.42V)
            • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
          • PPVRTC_G3H (3.3V)
            • This
          12-12-2024, 05:50 PM
