Toshiba Satellite L840 freeze at loading windows
    Hi..i have a problem on my customer toshiba Satellite L840 freeze at loading windows..already change hard drive, ram .. but still same problem.. also i have flash the bios..
    try install windows 8, but also freeze at loading windows..
    board code.
    Re: Toshiba Satellite L840 freeze at loading windows
    Southbridge chip, replace it.
      I dont think this laptop has a SB. It has PCH I think. Something like HM55 or HM65.
      Do you have a GPU or only CPU and PCH?
        Forget to mention, already changed HM76..still same problem
          Remove card wi-fi and test again
            I have remove wifi card..same problem..
              intenta trabajar sin colocar bateria
                What you mean? Change bios battery..? Already change...cpu also
                  Does that tohiba has proadlizer capacitor? If does change it...If doesn`t check all capacitors in cpu vrm section...
                    the laptop use this capasitor
                      check voltage + 5vs, may be dropped when loading windows
                        And replace these 3 bigs blacks caps.
                        Did you try to boot from Ubuntu?
                          Voltage ok...
                            i don't have cap 560..only have 330..posible to replace 560?
                              Just put one more. Or test them out if they are really 560.
                                Try to replace this capacitors...if not you can add one ads proposed but just for testing purposes...than if it works change them properly...
                                  Anyone have this laptop schematic?
                                    hopefully match the one you are looking for
                                    schematic:
                                      schematic:
                                      Thank you meritosari
                                        I solved similar problem with another model toshiba by changing the hdd socket
