Acer Aspire S7-392 Power Failure
  • jacen17
    • Feb 2016
    • 7
    Hi all
    I recently spilled a glass of liquid on my Acer Aspire S7 and since then the laptop has completely died (no LEDs, fans, power of any kind). I am an EE familiar with power electronics, but not really PC power architecture, so I am learning as I work through this.
    I've completely disassembled the laptop and am powering just the motherboard with no other peripherals (SSD, fans, etc). I have verified that 19V is good and my 5V_S5 and 3.3V_S5 are good and I also have USB power. I have also validated that the power button sets KBC_PWRBTN# to 0V when pressed. I have not detected any short circuits anywhere (surprisingly), although parts of the board visually look somewhat "corroded".
    The power state machine seems to be hanging at the KBC assertion of RSMRST# which is stuck at 0V regardless of the power button being pressed - this is preventing the remaining power from coming up including the CPU. From reading other posts on this forum this pointed me to a potential BIOS issue. I hooked up the BIOS SPI flash U2501 (schematic attached) chip select pin to my oscilloscope and it is stuck at a DC 2.7V, looks like data is not transferring so as I understand it, the BIOS is likely corrupted...right?
    So my questions are
    1. Am I going down the right path? Does it seem like there is an issue with U2501 either firmware or hardware?
    2. How can I flash the Winbond SPI Flash device U2501? Can I do it on-board? What type of programmer should be used?
    3. Acer has BIOS files on its website, but they are .exe's - how do I access the raw files (not sure what file extension) that the programmer requires?
    The attached schematics have a power flow diagram on pages 99 and 100, although the state diagram on sheet 99 looks slightly inaccurate and may be for a different board.
    Greatly appreciate any guidance here
    Thank you
    -Jason
  • jacen17
    • Feb 2016
    • 7
    Re: Acer Aspire S7-392 Power Failure
    OK, so I think I can find a programmer at work and should be able to flash the BIOS but I'm having trouble finding the .bin file - Acer only provides an extractable .exe with a .fd and some other files in it. Since I'm programming the chip directly rather than through a USB interface, where can I find the .bin?
    thanks
    -Jason
    • toufik sat
      • Feb 2016
      • 136
      • los angles
      Merci thank you
      • jacen17
        • Feb 2016
        • 7
        Alright, so I was able to reprogram the BIOS using a CH341A programmer I bought on Amazon. I found a .bin file online, but have no idea if it is good or not, all I can tell is that the file size matches up to the size of the PROM.
        I did read and save the original .bin file that was on the EEPROM but I don't know how to tell if it was even corrupted in the first place.
        Either way, no change to behavior with the new BIOS image on the EEPROM and reinstalled on the board. Chip is getting power, but no activity on clock or data lines (stuck at 0V) and CS is stuck at 2.7VDC.
        I know the KBC is getting power because it is putting out 3.3V on the PB_RST signal. What else can I check for at this point?
        • highpulse
          i hate HP
          • May 2013
          • 1490
          • portugal
          tell us board code for we can provide a good and correct dump . but alltough if water was spilled on board , you got certainly dead components , specially resistors !!!! chek carefully the water damaged areas , and with c«schematic , chek if resistor have same value as mentioned on the schematic , somethings is wrong on voltage rails , so thats why it wont turn on ... you can try bios .. but sincerely after water spill no longer turning on , doesn't seem bios issues !
          • highpulse
            i hate HP
            • May 2013
            • 1490
            • portugal
            wich bios pin have you noticed does 2.7 volts ????
            • jacen17
              • Feb 2016
              • 7
              The motherboard is a Wistron Storm 2, part number 12302-1, revision 1, if somebody had a BIOS dump I'd be very grateful.
              The pin stuck at 2.7V is Chip Select, pin 1.
              I will do a more in depth look at KBC power and surrounding components. I have already had to replace one resistor due to corrosion.
              • jacen17
                • Feb 2016
                • 7
                I'm going to attempt replacing the KBC. Looking under the package with a microscope there looks like a lot of residue. It's a high density BGA package so I might need to send it out to be replaced. I can buy a replacement on ebay...
                http://www.ebay.com/itm/Lot-of-iTE-I...-/252094880315
                All the power to the chip is good that I can tell - I know this because the KBC is putting out 3.3V on the KBC_PWRBTN# pin so the chip has power.
                Dumb question...does the keyboard need to be connected for the KBC to work? I have no peripherals connected to the MB.
                • chrisart
                  • Dec 2012
                  • 7
                  • philippines
                  GOOD DAY., having a 2.7v in CS pin on your spi chip most likely your chip is deselected, means no process data from spi chip..im having the same problem of yours and still i cant find any solution.,i have change working KBC (SIO) chip from another same and working motherboard but no changes..hope we're find an answer from the master..
                    ACER Aspire Aspire G7200 Predator Defender Aspire 9750 Specification for Upgrade or Repair
                    This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                    09-12-2024, 03:28 PM
                    ACER Aspire Aspire X1300 Aspire Specification for Upgrade or Repair
                    This specification for the ACER Aspire Aspire X1300 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire X1300 boardview and Aspire Aspire X1300 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                    Acer Aspire Aspire One 532h Netbook One Specification for Upgrade or Repair
                    This specification for the Acer Aspire Aspire One 532h Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Aspire One 532h boardview and Aspire One 532h schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                    09-06-2024, 05:27 AM
                  • Bonaventure Vigil
                    ACER ASPIRE A515-52G CAN ON BUT NO DISPLAY, NO POWER AT VCC_GT
                    by Bonaventure Vigil
                    Dear All,
                    Please really2 need Help on this Acer A515-52G Motherboard Compal EH5AW LA-G521P Rev: 1A.
                    At first this laptop can on, keyboard light on but no display. Open the motherboard, found out the PQZ3 Mosfet and PUZ3 ic near it burn. Refer picture below. Then I replaced both. All the power rail 3.3,5,1.2, 1.35, 0.8V have power back after i turn on the laptop except for the VCC_GT rail. Voltage at Power Supply showing 0.000A before turn on, after turn on it became 0.5 0.6A. Seem cannot boot and still no display. Then I replaced the PUG1 and mosfet, but the VCC_GT still no power....
                    12-12-2024, 10:22 AM
                  • ithe
                    Acer Aspire V5 571P 6499 power on but no display or no access to BIOS
                    by ithe
                    I am using this Acer Aspire V5 571P 6499 laptop for a long time. Laptop does powers on, but no display after properly shutdown while in its last working condition.
                    Laptop model - Acer Aspire V5 571P 6499
                    MoBo - Husk MB 11309-4M 48.4TU05.04M
                    HW config. i5, 4 GB RAM,250GB SSD, Windows 10 OS
                    status when laptop turned on
                    no display no logo no BIOS access
                    status - power led on, charging led (when power adaptor connected), led on power switch glow when power is on.
                    fan spins and stops for a minute and again start spinning....
                    10-31-2023, 01:59 PM
