Hp 15-r015dx strange fault
  • smali
    • Sep 2014
    • 287
    • Pakistan
    when i press power switch the power LED comes on and after after 7 second it goes down in the mean time when i check the voltage so the RAM 1.35 voltage is missing but some time when i touch the processor heat sink or near area some the RAM voltage comes and circuit start OK but not deduct HDD or other booting device.
    so what you experts are suggested about above two faults .
  • the-sky-blue
    • Dec 2013
    • 48
    • salfeet
    Re: Hp 15-r015dx strange fault
    chick if it clean >>
    then use the hater gun at 260c on (Intel chip) 4 seconds then Wat to be coll
    • smali
      • Sep 2014
      • 287
      • Pakistan
      Thanks for your reply..the problem solved.
      The fault was from 32KHz frequency XTAL which was damage.
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
        Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
        I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
        The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
        Now...
        06-09-2024, 10:57 AM
      • electron_jj
        Panasonic TH-L42D25A checking the PSU output voltage
        by electron_jj
        Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
        I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
        08-29-2021, 08:13 AM
        ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
        3+1 Voltage Regulator for IMVP-7/VR12 CPUs
        Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
        core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
        configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
        serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
        Based on Intersil's Robust Ripple Regulator...
        11-05-2024, 03:24 PM
      • ruletero
        Acer a515-43 low battery charge voltage
        by ruletero
        Hi
        Acer A515-43
        LA-H801P
        Fail: Does not charge battery, has low voltaje on connector.
        Laptop didn't want to turn on, only charge led blinked.
        I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
        I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
        Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
        10-24-2022, 02:31 PM
