programmer for ITE , ENE and SMC KBC ,
    i've been running across the internet searching for a good programmer to flash the iembedded ec on the kbc , i was going to buy one , but then a friend on vinafix told me that the ene 9012 was not compatible on minipro programmer , so i would like to know wich programmer i can buy to flash all kbcs that need to be flashed .
    send links , thk for the info and help
    Re: programmer for ITE , ENE and SMC KBC ,
    I think that RT809F is good , i'm thinking about buy this programmer ..
    i have minipro too...
      http://www.ebay.com/itm/SVOD-Program...4AAOSwnNBXbhrd
      I don't have decided to bought this, but i think this is the best but so expensive, and i think is too much easy to use.
        not so epxnesive , since it also test keyboard line and EDID LCD its a fair price , but im not sure if this will be compatible with my programmer
          http://www.ebay.com/itm/RT809F-Set-U...3D251316521321
          Any opinion about this?
            its so stupid this KBC flashing thing , it makes me to buy a dam new rom flasher for i can program a dam KBC ...since there is no compatibility with minipro tl866cs
              yes , this past days i've been searching a lot about this..
              ( i've send you a PM a few days ago about it )
                I use a SVOD programmer for the KBC. Programs through the keyboard connector.
                  What are the limitation of this programmer? are there any sio it wont work with?
                    Out of stock currently:
                    http://www.ebay.com/itm/KB9012QF-EDI...item1c50ab14fb
                    There is an adapter for nuvoton also...
                    SuperIO is not ordinary standardized spi flash - so there is "no one programmer" to do them all.
                      SVOD looks like it supports KB9012.
                      I have only had time to use it on one laptop so far.
                        Is there a list of KBC's that need to be programmed?
                          It's a shame that the TL866 doesn't have the KBC chip compatibility. I doubt there's any technical reason why the hardware wouldn't be up to the task. You would have to wire it up correctly, but it's the same thing with the RT809F. The SVOD looks like the only programmer out there that let's you connect via a keyboard ribbon cable and choose the pinout in software, but it's almost 3x the price of the RT809F.
                            WEELL GONNA ORDER THE SVOD THEN
                            can't stay without it , got a few machnes here stoped to fix waiting a ec kbc flash
                              me too i order this programmer but what is the difference between this 2 is the same seller 2 different price ?
                              http://www.ebay.com/sch/i.html?_odkw...ammer&_sacat=0
                                expensive one has more cables and one extra adapter board - just from the foto's
