Acer ES1-511 (E15 series) not charging
  • commandlinegamer
    • Nov 2011
    • 6
    Seems to be a few models in the above series exhibiting this issue, some not even a year old, from searches I've done.
    Machine will power on if connected to mains, but will not from battery, even if sufficiently charged.
    Anyone know of a common factor? Faulty mosfet(s)?
  • CeeEee4
    • 43
    • EU
    Re: Acer ES1-511 (E15 series) not charging
    i also have several of the acer ES1 models and they do not charge battery, they run fine on mains but no charge.
    Does anybody else have the same issue, and have some information about it.
    • ldoctoru
      • Jul 2018
      • 9
      • romania
      i have es1-531 with the same issue.charging ic is dead.replace charging ic.But before check the mosfet(s) around the IC, on my board i have 3 mosfet`s
      • CeeEee4
        • 43
        • EU
        when you change charging IC did it work for you?
        heres pic of mosfets and IC from boardview file, what shall i check for.
        thanks
        • ldoctoru
          • Jul 2018
          • 9
          • romania
          check mosfets and if they are good change IC(check output IC on pin 5).
          In my case after i change IC, charging works
          what IC do you have on board?
          • CeeEee4
            • 43
            • EU
            can i check mosfets on board, or do i have to remove them and test?
            Charging IC is BQ737..
            i have 0V on pin 5 - (ACIN) when charger is plugged in. what voltage should be there?
            thanks for your help
            • CeeEee4
              • 43
              • EU
              Has anybody else had charging issues with Acer ES1 (E15) model laptops?
              • Wang Tingting
                Acer Nitro 5 AN515-57-536Q not charging
                by Wang Tingting
                I am trying to fix a Acer Nitro 5 AN515-57-536Q not charging issue, the laptop can boot from battery, adaptor or both. The battery LED is solid orange, but it doesn’t charge. The battery report from win11 looks normal, the acer care
                report is also good for battery.
                Following https://www.badcaps.net/forum/troubl...arging-circuit,
                • DCIN/VCC: 19.1
                • ACIN/ACDET: 3v
                • REGN/VDD: 6v
                • CMSRC : 19v
                • ACOK: 3.3v
                • ACDRV: it is 19v, not 25V(when charging, the ACDRV
                09-10-2025, 01:46 PM
              • abrahim110
                [Help Needed] Acer Aspire 5 A517-52G – Removed Onboard RAM, Now Working But Battery Not Charging
                by abrahim110
                🧵 [Help] Acer Aspire 5 A517-52G – Onboard RAM Removed, BIOS Mod Done, Battery Not Charging
                I have an Acer Aspire 5 A517-52G-53NB laptop.
                The onboard (soldered) RAM was faulty, so I physically removed the chip.
                I also successfully modified the BIOS using the SPD Removal Tool – the laptop now boots fine and works with an 8 GB DDR4 SO-DIMM installed.
                ✅ System status:
                • BIOS mod is done (SPD removed)
                • Laptop boots to Windows normally
                • RAM is detected and stable
                ❌ Problem:
                The battery is not charging:
                • Power adapter
                08-06-2025, 06:15 AM
              • CPUFiddler
                Acer Nitro 5 AN515-45 not charging
                by CPUFiddler
                Hi there. I am trying to repair an Acer Nitro 5 AN515-45 and it's giving me some trouble. I have access to SMD rework station, variable power supply, digital oscilloscope, thermal camera, multimeter, stereo microscope.
                This laptop will boot and run from the power brick and/or the internal battery, but it will not charge the battery. NirSoft BattInfo tells me the charge/discharge currents, so I'm confident in saying that it's not charging. In addition, there's no increase in voltage at the battery connector when the laptop thinks it's charging, not even a few millivolts.
                I've downloaded...
                03-19-2025, 07:44 AM
              • titomno2
                Acer A315-41G similar to AN515-42, AC OK Battery OK but not charging
                by titomno2
                Hi guys,
                I currently trying to figure out why the laptop of my friend did not charge.
                It is a Acer AN515-42 (Ryzen 5 2500U), I manage to make it works on AC and battery but no charging.
                At first it was not working on Battery, I discovered that PQ201 was knocked off and replace it => work on battery precharged on another computer.
                I also checked the small resistors between PQ312 and PQ201 and even if they are ugly values are OK.
                My issue, when I plug the charger computer off, it drains 0.25A during few seconds with amber light on (charging) then amber light blinks...
                06-11-2024, 11:52 AM
              • titomno2
                Acer Nitro AN515-42 Not Charging
                by titomno2
                Hi guys,
                06-11-2024, 02:54 AM
