W240HUMB-OD, Power related problem * 5VALW Not present*
  • alfasys
    • Apr 2017
    • 32
    • South Africa
    Hi there
    I am trying to fix this Proline laptop motherboard (W240HUMB-OD). the laptop is completely off, when check using my meter I can see 3.3V is Present at PL 10 but 5V is not present at PL9. I don't know what components exactly I need to check and how. Can you please help.
  • rookieme
    • Oct 2014
    • 396
    • Greece
    Re: W240HUMB-OD, Power related problem * 5VALW Not present*
    You can check the resistance to ground of the PL9 for any short.
    If no short found is can allways be the PU11
    • meritosari
      • Oct 2010
      • 774
      • Indonesia
      As far I know, SMPS for 5V is appear after you pressing power button.
      Open it the pdf with PDF X-Change Viewer, its more easy to tracing the net voltage and signal on schematic, since clevo schematic sometimes very weird, I mean to many space on text on pdf.
      5V voltage doesn't present because the sircuit on VDD3 and VDD5 block diagram "playing the Entrip signal" with made PQ14 always ON state after plug in adapter.
      Make sure the output SMPS of VDD5 have no shorted. You could open PJ10 temporary just for testing output SMPS of VDD5 when you give trigger with shorting PJ11. (like: DD_ON signal become High after pressing power button, then DD_ON En VDD be Low as trigger)
      While you do that what i mentioned above, monitoring PU7, ITE chip if you see current drawn on your PSU drawn more higher ( I assume you have PSU), then cut off the supply from your PSU as soon as possible.
      • meritosari
        • Oct 2010
        • 774
        • Indonesia
        How its work likely similar with design from Inventec in example Perugia 10, with playing the entrip signal
        • alfasys
          • Apr 2017
          • 32
          • South Africa
          Hi. Thank you very much for your time and response. While trying to fix this motherboard, I removed uP6182 from the board because it was over heating then I tried to clean the board with alchool, one of the big IC fried (smoked) because I forgot to unplug the board from the charger.I know it's a huge mistake...I'm not sure I will have be able to fix it
          • rookieme
            • Oct 2014
            • 396
            • Greece
            you still have hopes, what IC is it?
            never plug in when you have removed a controller, mosfet usually burn without a controller to guide them
            • alfasys
              • Apr 2017
              • 32
              • South Africa
              Hi there.
              Thanks for your response. The IC that is burnt is U36. With the multimeter on diode mode (continuity) with PL9 removed on one side I have 380ohm (the side that is connected to the rest of the circuit) and Nothing on the side that is connected to PU11. What else can I test? Should I first replace U36?
              • rookieme
                • Oct 2014
                • 396
                • Greece
                The U36 is a combo LAN/card reader controller.
                You can safelly removed for now and don't bother to put a new one if you don't use your LAN or SD reader.
                Well the 380ohm are somewhat low for the 5V rail.
                Do remove U36 and take a new measure at PL9
                • alfasys
                  • Apr 2017
                  • 32
                  • South Africa
                  Hi Rookiem. thank you very much for your help. I am going to remove the the U36 immediately and take the new measurement
                  • alfasys
                    • Apr 2017
                    • 32
                    • South Africa
                    I will keep you posted
                    • alfasys
                      • Apr 2017
                      • 32
                      • South Africa
                      Hi I just removed U36. I was checking the board, I see that even u23 also burnt. do you thing I still have some hope?
                      I just removed it but there is still a short circuit
                      • rookieme
                        • Oct 2014
                        • 396
                        • Greece
                        You can locate the short by injecting 5V at the shorted power rail so you can find what component is heating up.
                        The issue is that the u23 is your keyboard controller IT8518E that is programmable, so you need a programmer for the new one and the file [EC dump] for this board so you can program it.
                        From this point I'm not sure if there is any hope if you can't find the required dump and a programmer.
                        • alfasys
                          • Apr 2017
                          • 32
                          • South Africa
                          Hi. Thanks for your response. I will just put it asude and deal with another biard.
                          • alfasys
                            • Apr 2017
                            • 32
                            • South Africa
                            *aside
                            • utitodson
                              • Sep 2016
                              • 19
                              • philippines
                              thank you for this thread it helps me found a short on 5v Rail -PL9 short to ground i hang it and found PQ12 and PQ13 short.
                              thanks again and more power to BADCAPS forum
                              from philippines
                              • Noreddin
                                • Jan 2020
                                • 73
                                • mostaganem
                                thanx
                                • pkslowk
                                  Debug Card Error Code and Solution
                                  by pkslowk
                                  Sr. Motherboard Debug Error Code Solution
                                  1 Intel 845 E9 Bios Related Problem
                                  2 Intel 845 D4 CPU Socket Related problem
                                  3 Intel 845 37 Bios Related Problem
                                  4 Intel 845 7C Bios Related Problem
                                  5 Intel 945GCPE 34 Bios Related Problem
                                  6 Gigabyte 845 2 Ram Related Problem
                                  7 IBM Server A6 A7 Ram Mismatch Problem
                                  8 Asus 845 29 CPU Related Problem
                                  9 Lenovo I946 97 C-Mos Jumper related
                                  10 Gigabyte 845 A0 CPU Related Problem
                                  11 Asrock G31M-VS D7 Bios Related Problem
                                  12 Compaq 845 BD-70G B0 CPU Socket Related problem...
                                  01-28-2021, 12:51 PM
                                • badboyzzz
                                  A2229 ipad pro 12.9 4gen strange problem Logic Board related charging but no usb data
                                  by badboyzzz
                                  I have a strange problem with my iPad Pro 12.9 4Gen / A2229. When I start the device, it stays on the Apple logo, but when I heat the back of the device with a hair dryer, the device boots, but this time there is an interesting problem. The iPad is charging, but there is no USB data on the computer. The USB charging port has been changed and the chips seem normal, but I have given it to 2 different Apple services in Latvia, but the repair could not be done. Is there anyone who can help with this? Can someone support the repair by sending only the motherboard within Europe? Thank you.
                                  12-28-2024, 02:11 PM
                                • javieromex
                                  Dell G15 5511 LA-K452P won't turn on
                                  by javieromex
                                  Hello, any help will be apprecited!
                                  • Model: Dell G15 5511
                                  • MB: LA-K452P
                                  • Issue: Won't turn on at all, no leds, no keyboard light, no fan spin, nothing happens when pressing power button. NOTHING.
                                  • Customer reported it was turned off and left plugged in during the night and thats it...
                                  • No signs of liquid damage or burned components.
                                  Link to Schematics -> https://www.badcaps.net/forum/troubl...la-k452p-gdp50
                                  I have checked so far:
                                  04-17-2025, 12:44 PM
                                • lapfix
                                  Lenovo IdeaPad 3 NM-C961.no display
                                  by lapfix
                                  Hello everyone.
                                  lap and motherboard : IdeaPad 3-15IGL05 Laptop - Type 81WQ
                                  NM-C961.
                                  Behaviour : connect charger it power on automatically ,reach 0.170 amp than down to 0.74 amp...no display.
                                  with battery connected it reach 980 amp than 870 ...no display
                                  No short ; no corrision no intervention before.
                                  Try 2 differents bios versions same behaviour.
                                  Some measuremets :
                                  PL 1600 = 5valw present
                                  pl 1100 = 3 vlalw present
                                  pl 100 = 0.221 v without battery and when battery connected 7.8 volt
                                  pl 6602 = 1.2 v
                                  pl 6603 = 1.056v...
                                  05-29-2025, 05:01 AM
                                • SDNarcia
                                  Dell 15R-5521 keyboard problem (KBC?)
                                  by SDNarcia
                                  Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                                  As additional information,...
                                  07-20-2024, 10:47 PM
