help me please toshiba qfkaa la-8391p
  • mon2
    replied
    Thanks so much for your update.
  • Kwisatz Haderach
    replied
    Another Toshiba P850 that works after soldering UCL1
    This chip provides clock signal for the RTC
  • mon2
    replied
    Re: help me please toshiba qfkaa la-8391p
    Search for a small rectangular black chip that will have 4 solder pins on each side. For a total of 16 contacts.
    This part will be 2mm * 3mm in size.
    It is a TQFN package so will be a thin height, quad flat shape with no pins but with flat solder tabs under the chip itself.
    Post picture of anything that may resemble this shape.
  • lxd4444
    replied
    Hello, i have this problemfrom the discussion, I realized that it’s a good option to resolder ucl1, but I don’t understand where it is located on the motherboard, even according to the diagram that was thrown off above (an ordinary stupid student who wants to bring his only laptop back to life)
  • kalu
    replied
    Found, if the RTC Battery have less then 2,8v the computer won't work, I change Battery for other charged and pc turn on OK
  • kalu
    replied
    Re: help me please
    Originally posted by vedoza View Post
    UCL1 check pleas
    No power on these pins... none
  • Kwisatz Haderach
    replied
    Another UCL1 reflow and sucess!!
    Thanks!
  • ranabp
    replied
    Thank you sir, ULC1 looked fine, but resoldering it worked.
    Cheers
  • drissisimo
    replied
    Don’t worked for me. Plz can you help me
  • REpairAT
    replied
    Worked for me, thank you friends!
  • paulosst1
    replied
    Hot Air in ucl1 and the laptop revive!! manny thanks
  • misiekelk
    replied
    Wow.Resoldered ucl1,working now.Thanks
  • englez
    replied
    Same problem,resoldered ucl1,working now.Thanks
  • ozy
    replied
    Re: help me please
    just had this fault and resoldered pu330, og1 and ucl1 and all working fine now.
  • vedoza
    replied
    Re: help me please
    UCL1 check pleas
  • piernov
    replied
    Re: help me please
    Check if you have PM_SLP_S4#, SUSP#, PM_SLP_S3#, SYSON and VR_ON signals.
  • atsio
    replied
    Re: help me please
    GPU or PCH. Probably GPU
  • mustafa007
    started a topic help me please toshiba qfkaa la-8391p
    toshiba qfkaa la-8391p rev 1
    power 5 seconds led worked with close
    vcore not voltage
    vram not voltage
    there are 5v and 3v
