Lenovo T410 keyboard issue
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    Good day folks. I'm in pretty deep doo-doos here because I might've busted the keyboard section of this Lenovo T410 laptop. Let me explain: I got it with a fan error, so I took it apart and sure enough it was clogged with dust, so I cleaned it, put it back together, it started up and booted just fine, everything was just fine and dandy until I discovered that part of the keyboard is no longer working, namely the area on the left like CAPS, S, Q, C and so on. I thought maybe it wasn't connected properly, so I took the keyboard off one more time and that is when I saw a hole in the middle of the ribbon cable ! A screw had poked through it It's because of the idiotic design which has the screw hole right next to the damn ribbon....why's it made like that ?! If you put the keyboard back on and the ribbon flexes just slightly, it goes right over the hole and that screw IS going straight through it !
    Realising there's nothing I could do at this point, I ordered a second hand keyboard (new ones being ridiculously expensive) and guess what.....it doesn't work either! So now I have two keyboards that don't work and a laptop which has no keyboard...great.
    Trouble is I fear the problem may be with the board and not the keyboard. The screw may have damaged something electronically because the keyboard I got looks decent enough (albeit slightly bowed) and was advertised as working, but it seems to fail in roughly the same area. I distinctly remember the S key not working on either of them for instance. I now ordered ANOTHER one, but this got me thinking that I might've busted the motherboard instead and I'm just wasting money at this point
    I'm not a laptop expert by any means, but I managed to get the schematic for this laptop HERE and had a look at the keyboard connector to at least try to get an idea of what might've gone wrong there....it's a bit too complex for me to follow so this is where perhaps some laptop mavericks could help me. Have a look on page 66 where the connector is and try to determine whether shorting something there may cause this behavior or "kill" part of the keyboard. Some wires go to page 64 straight into IC H8S2112(1/2). There are also various voltage busses like 3.3v and 5v present on that connector, so if the screw sent those somewhere they shouldn't be we can definitely get issues...I'm not sure how the keyboard even operates: does it have its own IC or are they just buttons that are read as on/off by that IC ?
    The two mouse buttons that are part of the keyboard don't work either, but the little red trackball thingy in the middle DOES work and so do other keys....it's just this one side that's failing. I'm not getting any "stuck" keys either, like a character that's typing continuously or anything. If I'm lucky I just got a bad keyboard and this next one will work, but if that's not it, I fear for the worst....cheers and thanks.
    Wattevah...
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: Lenovo T410 keyboard issue
    First, connect a USB keyboard and check whether all keys work properly or not while the internal keyboard is not connected.
    and never use the original broken keyboard again.
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      Yes, I forgot to mention: just to make sure, I did the USB keyboard thing and yes, all keys work fine on that one.
      Wattevah...
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        you mentioned you got two healthy internal keyboards. Now mention what keys are not working when the laptop uses either one of the two keyboards. In addition, measure voltage on fuse F13 and F21.
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          I actually only have ONE "supposedly working" keyboard (the one I bought and doesn't work), since the second one hasn't arrived yet - should do so tomorrow. I did notice those fuses but can a blown fuse cause only PART of the keyboard to cease to function ? :|
          Wattevah...
          • caspian
            • Oct 2015
            • 1591
            • Laptop
            To make sure, a photo of the damaged section of the ribbon cable would help. try to discover what keys are not working when the laptop uses either one of the two healthy keyboards. and see if the failed keys are the same or not.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              To me, it seems like a bad keyboard issue only-mb hopefully is not damaged. Lets wait for another keyboard .
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3628
                • slovakia
                look and beep through connector to be sure it is not damaged
                if not, u maybe shorted some power to data line with screw and kill something in your kbc
                • playit
                  ps/2 port keyboard dead ? p5ql pro / ethernet cable light
                  by playit
                  my system is p5ql pro asus mobo , logitech keyboard ps2 keyboard (more than 10 years) .
                  my place use to get some power drip for a second ,at that time , pc shuts and restarts itself , it dint cause any problem till now , once or twice i noticed , i am not sure if it was exactly at power drip time or normal time - both keyboard and ethernet lan stopped working , the keyboard would lose power i mean led lights-num lock caps lock would not stay on , no light at etherbet cable too..then i would restart the pc - then its all good .
                  few years back ps2 mouse stopped working, but ps2...
                  12-23-2024, 06:05 AM
                • FZG
                  Lenovo Yoga 6 (13ALC6) keyboard not recognized
                  by FZG
                  Lenovo Yoga 6 13ALC6
                  Model: 82ND
                  Board: LA-K211P
                  Schematic: https://www.badcaps.net/forum/docume...ic#post3482405
                  Hi guys!
                  I recently bought a Lenovo convertible Laptop (Yoga 6 13ALC6) in faulty condition. It originally had a corrupted BIOS but I was able to resolve this by flashing a clean bin. Now the laptop works fine except for one thing, the keyboard. It does not work in Windows but it works in BIOS setup. The keyboard itself is probably not at fault, every single key...
                  06-28-2025, 11:23 AM
                • MrDadosz
                  Lenovo Legion 15IMH05 keyboard problem
                  by MrDadosz
                  Hello, I have lenovo legion 5 15imh05 (board: nm-c911) and I have a problem with a keyboard.
                  When I hold power button for ~30 seconds or unplug RTC battery keyboard will work only one time. After laptop reset or shutdown, keyboard won't work.
                  In 90% cases when I unplug power supply and turn on laptop on a battery, keyboard works even after plugging power supply - I can't turn on laptop with a power supply and get keyboard working.
                  Shortcuts Fn + F1-F12 are working. Keyboard is fine.
                  I replaced IT8176FN-56A and reprogram it with a dump from previous chip and it worked for...
                  08-15-2024, 05:07 AM
                  HP ProBook 430 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse Notebook 400 Specification for Upgrade or Repair
                  This specification for the HP ProBook 430 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse boardview and 430 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you...
                  09-06-2024, 06:21 AM
                  HP ProBook 450 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse Notebook 400 Specification for Upgrade or Repair
                  This specification for the HP ProBook 450 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse boardview and 450 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you...
