2015 macbook air keeps shutting down
    i have a 2015 macbook air j113 820-00165 that keeps keeps shutting off i get green light on charger and turns orange when charging just wont stay running any help would be great
    Re: 2015 macbook air keeps shutting down
    Keeps shutting off? As in it will load into the OSX and than it shuts off?
      yep lets me sign in then shuts off
        Hold down D when you start up, it will run some diagnostics,let us know the results .
          it shuts off before it gets to the end of the line
          all power rails read normal must be a short somewhere
            I suspect a faulty heatsink...
            ASRock B550 PG Velocita
            Ryzen 9 "Vermeer" 5900X
            Arc A770 16 GB
            eVGA Supernova G3 750W
            Alienware AW3423DWF OLED
              is there a way to test that
                If it's seated properly, likely a broken vapor pipe...
                Arc A770 16 GB
                  broken vapor pipe ??
                    are you talking about the heat sink shield
                      No, the sealed pipe that runs between fins.
                      Arc A770 16 GB
                        really 4,083 posts and you think a piece of sealed pipe is why my macbook dosent turn on.. wow anyway found my short and fixed now but thanks for the bright idea
                          I suspected the heatsink, because you got as far as login...
                          Arc A770 16 GB
                            can you share how you solved the problem and where is the short.
