HP G4-1015DX cmos problem
    I need help on this how to solve this problem on HP g4-1015dx BOARD IDA0R22MB6D0 REV. the problem is i need to removed and insert the cmos battery in order the laptop to start. because once it shutdown i need to removed cmos first before it boots fine.someone please help me on this
    Re: HP G4-1015DX cmos problem
    anyone need help please
      anyone please help on this i need to removed and insert the cmos battery in order the laptop to boot fine. please help on this please
        Schematic: http://www.s-manuals.com/motherboard/quanta_r22
        Check the CMOS battery voltage. On page 12 of schematic, check all caps ,resistors,diodes on +AVBAT .Check Y3 xtal .
          thanks for the schematic smdflea, i back again here at first i change only cmos it works but now the problem came back and still the same issue need to removed cmos and plugged in in order to boot the laptop fine, so i did some measurements based on you advise and schematics, here it is on page 12 R269 measured 1.1k and has 3v when cmos is plugged in but 0.5v when cmos removed. the same on D21 both side have 3.v if cmos is plugged in but if pulled out only one has 3v the other side 0.5v only.but D22 both have 3v even cmos plugged in or out.any advise and help please
            need help on this please
              Test C673 and C675 for short ,if ok change Y3 xtal .
                i cannot find the Y3 C673 and C675 located.could you help me please
                  I just noticed that you have a revision D board .There`s a boardview available for it, but i don`t have it.Its on the paid sites .
                    maybe someone can share on this board view please i could not find the Y3 c673 and c675 located on the board
                      Need help please
                        need help please
                          still i cannot find the location of this C673 C675 and y3 could anyone help me on this please
                            I found the rev D boardview .
                              i think flashing bios can solve ur problem
                              backup old and flash bios
                                @smdflea i cannot open the file because it is .bdv @ganeshcell already done flashing the bios but still the same issue
                                  https://openboardview.org/
                                    try this software
                                      try this
