Laptop Motherboard Repair
This topic is closed.
  • Pesti
    • Apr 2010
    • 21
    Re: Laptop Motherboard Repair
    Well here's a good one on the HP dv series with ffc power cables, replace them, even if they look good, The originals are crap and I personally had two DV6000 that I went thru the ringer with trying to diagnose them until I read an obscure thread on a music forum of all places, One guy said he had a friend that worked for an HP supplier, and that there was a lot of "Rukus" about a ****load of crappy ffc cables......anyway on a whim I took down one of the offending laptops and switched around the two ffc cables from the power board, since they were both the same pin count and size, and VOILA!!!~
    What a bunch of crap, believe me I thought I checked the power circuit pretty thoroughly and I really thought I would have caught this...That laptop has sat on that shelf for almost a year........
    • Pesti
      • Apr 2010
      • 21
      Found this little Item on testing MOSFETS If anyone's still interested
      http://www.electronicrepairguide.com...t-testing.html :>)
      • Flounders98
        • Feb 2009
        • 5
        #83
        I have a DV6500 with no power on from battery or a/c. I do have blue ring around a/c adapter. The mosfet on the top of the board near the battery connector marked pq30 is a 4856a. I measured this ic in diode mode and got 450 and 0. I have 18.5v on this ic but not on the bottom one near the power in connector. That ic is marked pq3 6679gm it reads 430 and 93. I think i will replace both, but i cant find a replacement for the 4856a. Does anyone have any suggestions on a possible replacement for the 4856a?
        • chevelle_nut
          • Dec 2008
          • 62
          #84
          Can you post a picture of that area of the board? My schematics aren't matching up. I just went through this and found a bad zener as well as the 2 mosfets were needed.
          • Flounders98
            • Feb 2009
            • 5
            #85
            chevelle_nut
            I wont have access to my digital camera until Monday, but this board is totally different from the dv6000 and 9000 i have seen before. Can u elaborate more on your repair? Do you have a schematic available? Can you recommend a replacement for the 4856a?
            • mandacat
              • Apr 2009
              • 7
              #86
              Seems like a great subject / thread - anyone plan on continuing it ??
              • ozer44
                • Feb 2011
                #87
                Hi, i have a hp compaq nx 7400 but my laptop not charging and not power on.. i have a another problem TPS51120 very hot... What can i do?
                thx
                • Pyr0Beast
                  • Feb 2009
                  • 406
                  #88
                  Replace mosfets on 3.3V and 5V line and replace TPS51120
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 4951
                    • New Zealand
                    #89
                    Originally posted by stj
                    if you find a shorted rail - in anything,
                    a low-ohms meter will find the exact component real fast without lifting stuff.
                    years ago everybody built there own low-ohms devices - often using a speaker that changed tone.
                    very handy kit.
                    Do you have any recommendations for a design of one of these?
                    -David VanHorn
                    • severach
                      • Aug 2007
                      • 1055
                      Leak Seeker
                      I have one but haven't figured out how to use it. I have much better luck applying bench power to a shorted circuit and see which component heats up.
                      sig files are for morons
                      • Setarkos
                        #91
                        Hi im thinking about buying leekseaker for laptop pcb board
                        but im afraid its gonna do wild with all the coils.
                        Could anyone who got that device could tell me is it a good buy for laptop pcb diagnostics.
                        Becouise im afraid it will be a waste of money.
                        • Pyr0Beast
                          • Feb 2009
                          • 406
                          #92
                          Could be useful. Not sure where it could beat a standard multimeter.
                          • severach
                            • Aug 2007
                            • 1055
                            A common problem with laptop boards is a shorted ceramic or tantalum capacitor shorting out a single supply or the entire system supply. If 20 ceramic capacitors are in parallel and one of them is shorted, all 20 will show as shorted. A DVM will show you the list of 20, which is important to know, but it can't pinpoint the bad one. The Leak Seeker and the bench supply can. I just haven't spent the time with the Leak Seeker instructions to figure how to use because the bench supply finds them so easily and so fast with no downside. Even if a major chip is shorted the bench supply finds it easily, just as the Leak Seeker would.
                            The Leak Seeker measures the resistance as you place the probe along a shorted path. To a regular meter the shorted path has zero resistance. Like an ESR meter, the Leak Seeker is equipped to measure very small resistances so the path resistance is measurable. The Leak Seeker knows the resistance of the entire path and it knows the resistance from where the roving probe is placed. The probe point completes a voltage divider circuit. The closer you get to the shorted the component, lower the resistance of the lower divider and the more noise LS makes. Measuring resistance down near 0.001 ohms is not trivial and requires some setup. I haven't been forced into learning how.
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 4951
                              • New Zealand
                              #94
                              Isn't your "smoke out the shorted part" approach a little dangerous - aren't you at risk of burning PCB tracks this way?
                              -David VanHorn
                              • Pyr0Beast
                                • Feb 2009
                                • 406
                                #95
                                Eh. I just hook up a 1.2V nicd battery there and see where it smokes.
                                • severach
                                  • Aug 2007
                                  • 1055
                                  The point of the bench power supply is to add just enough power to get the part to heat up. If a trace were to heat up I'd know that the shorted part is far away. So far all the caps have been connected with really big traces--probably power planes that I couldn't possibly heat up.
                                  • infringer
                                    Badcaps Member
                                    • Sep 2009
                                    • 244
                                    • United Frickin States
                                    #97
                                    So its safe to say some of the common tools we will use are:
                                    Desoldering Braid / Desoldering Iron
                                    Soldering Iron / Station
                                    Hot Air Rework Station/ Ceramic Heater / Toaster Oven / Heatgun last resort
                                    ESR meter
                                    Digital Multimeter
                                    O-Scope if you can afford one
                                    I don't mind using redneck tools if need be I've done repairs with a heatgun and have been successful.
                                    So a nice list of tools required for laptop repair would be of the order and here is a good start.
                                    Benchtop adjustable power supply 3.3v 5v 12v should be the common voltages used.
                                    Please note: I am not responsible for any harm caused to you anything discussed is just discussion. Before you try anything discussed be sure that you have the appropriate knowledge and safety gear for the job. Like with anything education and safety are first! Do not try anything @ home without it.
                                    • mattbrad2
                                      • Jan 2011
                                      • 122
                                      #98
                                      severach, can you walk me through your process of using a bench supply to test these shorts? Say you have a ceramic cap shorted on the opposite end of the dc jack, close to the charging circuit. Where are you applying voltages and what voltages are you applying? On a 19v (or 10-14v) rail, what voltage would you start at and how are you measuring "heat"?
                                      • flex1
                                        • Nov 2011
                                        • 5
                                        #99
                                        Can anyone give a brief explination of how to use a bench supply to "smoke" out the shorted componant ? i know its probably not good practice but i have a couple of boards that i have extensively tested with my meter but have been unable to find the shorted part, i figure i have nothing left to loose if i damage the boards even more so might as well give it a go, do i connect the bench supply to the DC Jack input ? and what kind of voltages / amps would i be looking to use on a board that requires the standard 19v
                                        Thanks Ste
                                        • Agent24
                                          I see dead caps
                                          • Oct 2007
                                          • 4951
                                          • New Zealand
                                          #100
                                          Having never done this myself, I may be wrong!! Wait for someone else to confirm!
                                          But, I would think, don't apply to the DC input jack unless your short is across it. Otherwise you may blow all sorts of things that aren't shorted with too high voltage or such.
                                          Probably what you want to do is find the part\branch of the circuit where you have found the short, verify there is in fact not supposed to be a short, and apply power there, and see what happens.
                                          I expect you'll need a supply with current limiting. Start off with a low current and work up, keep looking for signs of overheating components.
                                          If you go too high you could burn out a board trace, then you'd really be screwed.
                                          And remember, components like inductors can look like shorts to a DC ohmmeter, when they're not really!
                                          -David VanHorn
                                          • Geeker007
                                            Friend messed up my laptop motherboard while working on my bench
                                            by Geeker007
                                            Hi All,
                                            So my friend was visiting and he wanted to use my solder bench to solder on some WLED circuit board. My laptop was open on the side for RAM upgrade. I know my mistake.
                                            So while soldering he had too much solder on the soldering iron tip and he just shook off the soldering iron on the table itself to remove extra solder on the soldering tip and it landed on the motherboard of laptop. He then out of fear tried to remove it using solder wick and did more damage by removing some components as well. So here I am with weird situation.
                                            I have not tried putting...
                                            06-16-2025, 01:40 PM
                                          • Username338
                                            Laptop BA92-09470B motherboard schematics
                                            by Username338
                                            Thank you for deciding to read this topic!
                                            Laptop: NP700Z3A-S02RU
                                            Motherboard: BA92-09470B
                                            I was trying to fix my old laptop that has stopped displaying image a long time ago. It boots up, lights light up, fan spins but no image. Conned it to TV by HDMI cable, but it was unsuccessful. Components look intact, no water damage/corrosion on the board.
                                            I don't really value this laptop too much, so I wanted to ask anyone for a schematic/boardview file or anything that describes motherboard in a simillar faison. I want to experience a challenge of figuring...
                                            03-09-2025, 03:52 PM
                                            Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                                            09-06-2024, 09:30 PM
                                            Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 08:47 AM
                                          • RdeveLabs
                                            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                            by RdeveLabs
                                            To all the members here...
                                            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                            05-05-2025, 04:59 AM
